1.21.3.1, that makes more sense, 1.22.0.1, I downloaded it, but it is not 880MB.
Are you sure you click the correct download First time I did it , click download for the one I need and for some reason it was the wrong one went down to the end of the list of fixes and it downloaded the right one.
Anyone who has installed this latest update, and you have the time, please check to see if you can check your Info Data screen that has the oil pressure displayed, before turning the radio on. I don't think the last two updates would allow that, but the version i am still using allows that, so you can check your oil pressure immediately after starting the bike with the radio off.
are you sure you click the correct download first time i did it , click download for the one i need and for some reason it was the wrong one went down to the end of the list of fixes and it downloaded the right one.
Holy ****.
The irritating "reading USB...", message is finally gone!
The press to skip warning message actually works too.
68 XLCH: With my bike not running (ignition on or accessory) and the radio off, you cannot bring up the oil pressure.
Not sure that is normal, but I'm not starting the bike to fully check because GF is sleeping (night shift).
Hopefully someone else who will start the bike will chime in.
I believe the POI D/L is from June 2017, so nothing new there.
The SW I downloaded is dated 7/11/17. It could be an update or it could be software was modified to make installation easier without any changes to the dealer database. I don't have access to my cycle to verify anything - just what was downloaded.
I just realized that when I posted this on 12/8, The HD website said the update was released on 12/11 and today is 12/10. "Let's do the time-warp again".
Installed both dealer update and 1.22.0.1 both went with out any issues.
Don't understand the issue with oil pressure display with radio off but no with radio in off it does not . Not sure it ever did I never shut it off, May mute it but never off.
