Version: 1.21.3.1 Update
Old Dec 8, 2017 | 01:51 PM
jeff53404's Avatar
jeff53404
Default Version: 1.21.3.1 Update
Cycle is tucked away for the winter so I won't be trying it out.
https://www.harley-davidson.com/us/e...-download.html
When you select Premium or Premium CVO, the 1st black box to download software will be the Dealer Location Update database. If you want the major update, scroll down to the next black box. The dealer database is 7/11/2017. I do not know if this is a more recent version.
Date Released: 12/11/2017
File Size: 880.8 MB
Fixes
• Arrival time showed the current time after user deviated from a route.
• Next turn area displayed an arrow with the current street name.
• Special Alpha Jump characters were not displayed.
• The SMS (Short message service) repeat button wouldn’t read the message clearly if pressed multiple times before it has completed the readout.
• Audio paused after loading a ringtone.
• VR (Voice recognition) not working after an ignition cycle.
• Local media preset inconsistent between shutdowns.
• User was unable to search for preferred POI (Point of interest) after simulation sleep.
• Constant “Game Start” pop-ups.
• Presets from USB (Universal serial bus) drive 1 were still visible on USB drive 2 but not highlighted as available.
• Albums and artists heading were mismatched with list.
• AM (Amplitude modulation) radio presets not highlighted when USB was unplugged.
• Repeat button NOT enabled on first selection.
• Pre-cal reset did not delete trails.
• Accept screen appeared for less than 15s after exiting User Off mode.
• Saving or editing emergency number did not work.
• No SiriŽ pop-up displayed while saving an emergency number.
• Text was missing in the maneuvers list after switching to high contrast mode and then back.
• No initial Siri pop-up initiated.
• Cancel noise was heard when going from VR to Siri.
• Prompt Volume was not updated after changes in Feedback Settings.
• GPS (Global positioning system) entry changed W(O) to E in Spanish.
• WHIM (Wireless headset interface module) – Low battery pop-up was not shown for passenger headset.
• WHIM – Paired BluetoothŽ device name appeared as “Headset”.
• Repeat prompt was not working.
• SiriusXMŽ weather map did not maintain the default zoom level.
• User off mode enabled navigation prompts.
• VR conflict if Siri was launched from phone at the same time with the radio.
• Saved USB presets for drive 2 were replaced by drive 1 after an ignition cycle.
• USB saved as favorite was not highlighted after an ignition cycle.
• Distance to next action bar disappeared before route recalculation instead of being grayed out.
• “Navigation is not ready” displayed when initiating navigation command to “Find Next Gas Station” via VR.
• Various bug fixes
Old Dec 8, 2017 | 02:01 PM
hbsoldier3's Avatar
hbsoldier3
How do they go from 1.23.1 to 1.22.0.1??????????
Old Dec 8, 2017 | 02:51 PM
Red's Avatar
Red
It was 121.3.1
How did you find this update dated 12-11?
Old Dec 8, 2017 | 03:09 PM
hbsoldier3's Avatar
hbsoldier3
Originally Posted by Red
It was 121.3.1
1.21.3.1, that makes more sense, 1.22.0.1, I downloaded it, but it is not 880MB.
Old Dec 8, 2017 | 03:21 PM
Sierra977's Avatar
Sierra977
Loading "CVO" update on non-CVO SGS as we speak.
Old Dec 8, 2017 | 03:26 PM
hbsoldier3's Avatar
hbsoldier3
I only get 17.8 MB for the swdl file.
Old Dec 8, 2017 | 03:32 PM
penmaker's Avatar
penmaker
What is the advantage of loading the CVO version?
Old Dec 8, 2017 | 03:34 PM
hbsoldier3's Avatar
hbsoldier3
The last time I did it the start up screen said CVO. Other than that I do not know.
Old Dec 8, 2017 | 03:38 PM
Sierra977's Avatar
Sierra977
.zip file I got is 886.2 MB and un-zipped .iso file is 1.03 GB
Did you get the POI file by mistake? It's easy to do on the new web page. The file you want is linked at the bottom of the section.
Old Dec 8, 2017 | 03:39 PM
penmaker's Avatar
penmaker
Thanks. Comparing the two I don't see any difference. I didn't know if there were certain functions that the CVO update would enable or not.
