Squeak When Leaning
Old Feb 23, 2020 | 03:53 PM
toastedoat's Avatar
toastedoat
Default Squeak When Leaning
So I've got a weird squeak on my bike (2014 Limited) coming from somewhere in the front that happens only when the motor is running and the bike is leaned over, either on the kickstand or if i lean it to the right while not moving - basically I can make it happen and go away at will by just leaning or standing the bike straight up. It happens while riding but I only hear it when I'm turning/going through a curve no matter what speed. Engine runs strong as ever, performance doesn't seem to be affected by it. At first I thought it might be the wheel bearings, but since it happens at idle on the kickstand that isn't it. Now I'm thinking it's the front motor mount - I've grabbed and held so many parts with it happening it's amazing my hand hasn't burned off
Anyone ever have anything like this or have any suggestions?
Old Feb 23, 2020 | 08:58 PM
timbo141's Avatar
timbo141
Sounds like squeaks and rattles can travel, here are some areas to check.
Muffler brackets under bags have a rubber isolator that can cause it.
Exhaust mount by passenger right floorboard loose
Exhaust heat shields loose
Header loose at cylinder exhaust port
Old Feb 24, 2020 | 09:15 PM
Grouser62's Avatar
Grouser62
Agree with all the above possibilities and OP you may also be correct in identifying the top motor mount. Try a squirt of wd40 or better yet Jig-A-Loo. That always shuts mine up and then when the sled is next in the shop I ask them to re-torque the fastener.
Old Mar 1, 2020 | 12:45 PM
Lunchboxx's Avatar
Lunchboxx
I have a 2015 Limited and have the exact same issue. I will check the above mentioned items. I dont notice it when I am riding but definitely at an idle on the jiffy stand, but goes away when I stand the bike up.
braap_27
Apr 23, 2018 12:06 PM
stevequad
EVO
30
Nov 24, 2014 03:30 PM
ehc0720
Aug 6, 2012 02:11 PM
smithbrl
Jan 22, 2011 12:52 PM
tincup64
Jun 20, 2010 09:55 PM
