Clairify 103 to 110
Old May 4, 2020 | 07:11 AM
Magnut1's Avatar
Magnut1
I am going to get the part number of the heads, which were for a stage 4 103 and see if the 110 big bore kit needs 110 size 4 inch gaskets.
Old May 5, 2020 | 07:59 PM
Tail Rid'r's Avatar
Tail Rid'r
Originally Posted by Bafflingbs
Fuel Moto is installing their 110 kit, with heads and cams, for me, on the 11th. I’ll let you know how it goes
Which set of cams did they quote your build on...777"s?
Old May 7, 2020 | 03:12 AM
Bluehighways's Avatar
Bluehighways
Yes, it needs the 110 4" Gaskets. I've had good luck with the Cometic MLS Head Gaskets. Plus they're a bit thinner than stock and that gets you a very slight bump in the Compression Ratio, which is a nice benefit.
Old May 7, 2020 | 08:52 PM
Bafflingbs's Avatar
Bafflingbs
999-6A’s
Old May 8, 2020 | 03:07 PM
Stoney Lawson's Avatar
Stoney Lawson
Originally Posted by Bluehighways
You can turn a 103 into a 110 but you either need to bore the case to accept the larger diameter spigot of the original equipment 110 cylinders that come on the CVO's -OR- you can purchase a drop in 110 piston and cylinder kit from Harley. (Harley Part Number: 92500039) This "kit" uses a steel cylinder liner inside the cast iron cylinder barrel. Using a steel liner allows for a much thinner spigot. The spigot is the part of the cylinder that extends into the case. FWIW, the piston rings and thus the burning fuel mixture never get close to the spigot. Something VW and Porsche did decades ago on their air cooled engines. Anyhow as a result using this kit doesn't require that the cases be machined. I put this 110 piston and cylinder kit on my originally 103 2015 Ultra Limited (along with heads and cams, etc., etc.) and that was close to 20,000 trouble free miles ago.
Did you use the stock water cooled heads?
Old May 8, 2020 | 05:50 PM
Tail Rid'r's Avatar
Tail Rid'r
999-6A’s
I do like the 999-6a's...not looking to go with that kind of duration, but they just really seem to throw good numbers and show a nice curve. They do seem to build early and carry out to 5250 very nicely. Just never seem to see many done with 2-1-2 exhaust and when you do, they're done with disc style cans.
bobbleheadray
May 31, 2017 10:38 AM
Bingee
Aug 15, 2015 09:17 AM
GAstreetglide
Exhaust System Topics
25
Nov 26, 2008 08:21 AM
Dewky
Nov 11, 2008 03:06 PM
swampking
Motorcycles For Sale
Nov 10, 2007 12:49 AM
