EITMS & Cooling Fans
Old Jul 9, 2020 | 08:44 AM
'05Train's Avatar
'05Train
As mentioned, separate. You have the ability to adjust the temperature at which they activate through the Power Vision.
Old Jul 13, 2020 | 08:24 AM
alarmdoug's Avatar
alarmdoug
Originally Posted by BigDawgQC
Yes, I know what the fans are for & what the EITMS for. That wasn't the subject of my question.
Yes it was the subject of your question.
You asked if the fans would still come on if you disabled EITMS. I answered "yes"
I then went on to describe them as two different systems.
All good was just confirmed what others have posted in case you were in doubt.
Old Oct 31, 2020 | 08:25 PM
Time_Traveler's Avatar
Time_Traveler
I just picked up a 2014 FLHTK. From reading the above responses it sounds like the EITMS should be disabled?
Old Nov 1, 2020 | 11:24 AM
Sparkee...'s Avatar
Sparkee...
The EITMS does not control the fans. The fans are controlled independently according to ambient and engine temps. The EITMS shuts down the rear cylinder at idle for rider comfort not engine protection. Having it on or off is more of a personal preference. Some like it, some hate it. When activated on my twin cam it was very noticeable the rear cylinder was not firing and didn’t sound normal. Occasionally I found it was slow kicking the rear cylinder back it while leaving a stop light with a little stumble but not a big issue. On the M8 it has been improved quite a bit. It’s hardly noticeable at idle and transitions back quite smoothly when it is deactivated. Personally I leave it on all the time.
Old Nov 9, 2020 | 07:10 AM
Sandcrab's Avatar
Sandcrab
Default Eitms
I also keep mine on all the time. When I stop at a light for instance, and click over to the EITMS screen, it shows "enabled" and if it is a hot day, it will show "active" and I have never had a hesitation problem coming out. 2015 Limited 75,200 miles and counting.
Old Nov 9, 2020 | 10:58 PM
cficole's Avatar
cficole
I've occasionally had the engine hesitate coming off the line, but a little throttle blip before starting out will get the engine ready and eliminate the hesitation.
hardheaded
2014-2024 Touring Models
105
Jul 18, 2023 05:39 AM
Desert Hog
Audio Systems
Apr 13, 2020 01:22 PM
richie74
Sep 18, 2018 02:22 PM
JetRanger
Audio Systems
May 27, 2018 01:21 PM
roussfam
Audio Systems
16
Sep 24, 2017 07:57 AM
