rack and pull engine alignment
Old Dec 14, 2023 | 09:34 PM
Hulkss's Avatar
Hulkss
Originally Posted by btsom
Excellent presentation in your wheel alignment thread. I couldn't tell from the pictures what frame you had (perhaps easy for some, but not me). How does this work with the "new" frames (09 and newer) and with the cam adjusters, not the nut and bolt style? I can easily see vertical adjustments with an adjustable top link but the left-right adjustments are not as obvious as they were on the older frames and small wheel only left-right adjustments with the cams would seem to require a bit of grinding on one cam or the other.
I was showing my softail. The frame type and adjuster type does not matter. Just use the left and right axle adjusters (cam or screw type) to align the rear wheel and properly tension the belt at the same time.
No need to ever grind on the cams. One cam is locked to the axle and one is not.
Old Dec 15, 2023 | 10:08 AM
Max Headflow's Avatar
Max Headflow
The problem with the guy's theory is that the mounts themselves may not be straight.. When aligning wheel vertical with levels. The left top shock mount on my EGC was off by about 1/8 inch.. When they weldied the frame, it shifted in the fixture..
Old Dec 15, 2023 | 02:02 PM
btsom's Avatar
btsom
One cam is a welded part of the end of the axle, the other is keyed so that it must move with the axle when tensioning the belt. In mine I would guess that there is less than one degree of axle rotation before the keyed side follows the axle rotation adjustment. The design assumes that the swing arm and the lugs welded to it are true. From a practical standpoint, there is no independent movement of one cam relative to the other. My only Harleys have both been Road Kings so the cam system is all I have worked with. The system on the Soft Tails has always impressed me as superior as it is more adjustable.
Old Dec 15, 2023 | 02:08 PM
Hulkss's Avatar
Hulkss
I haven't adjusted my Road King yet. I thought there was a little more free-play on the loose cam end.
Old Dec 15, 2023 | 04:04 PM
btsom's Avatar
btsom
My machine rides pretty well now but I plan on getting the square tubes and angle iron to check it out. If you have any ideas after your first adjustment, please let me...or everyone know. "Massaging" any play on the loose side would only allow a very small correction and seems rather labor intensive to combine wheel alignment with belt tension. With any luck it would only need to be done once per tire change but still seems more difficult than the screw jack arrangement.
Old Dec 16, 2023 | 07:21 AM
JINKSTER's Avatar
JINKSTER
@Hulkss and @btsom Does anybody on these HD forums ever use or been introduced to "The String Method" of motorcycle wheel alignment?
Also? It appears to me the goal is to align the wheels and then align the final drive unto the wheels and I presume this is where that S&S adjustable length heim link comes into play but I don't see where unless we have the ability to loosen the motor mounts to allow the engine/trans to reclock/reposition themselves accordingly because I sure wouldn't want constant tension getting induced into my primary drive bearings where at the end of the day? While wheel alignment is important (a solid 9 on my 10 scale) the rest is hyperbole seeing how the touring models have rubber mounted engines with one counterbalancer (as opposed to the softails solid mounted engines with 2 counterbalancers) where the touring engines jump around like Shakira's hips on coke! LOL!
Old Dec 16, 2023 | 07:30 AM
DeeRoe's Avatar
DeeRoe
I throw a leg over. Head down the street doing 40-50mph on a straight road with cruise on. I take both hands of the bars and if I go straight, the bikes aligned enough for me.
I've ridden a few "crooked" bikes....none bad enough to make me worry about it.
Old Dec 16, 2023 | 11:43 AM
btsom's Avatar
btsom
I guess both of my Harleys have been a bit crooked. They both would drift to the left when hands off. I played with the 08 RK as it had more adjustability then the 23 but never trimmed out the pull. Loading everything heavy that I always carry into the right saddlebag eliminated most of the left drift. I could find no alignment section in the FSM, hope I didn't just miss it. The new frames (09 and newer) do not seem to allow for left-right adjustment and an adjustable top link must be added for vertical adjustment.
Old Dec 16, 2023 | 12:50 PM
Hulkss's Avatar
Hulkss
I've tried alignment with string but I was not confident that the results were good.
Old Dec 16, 2023 | 01:42 PM
bson's Avatar
bson
This only checks that the weight is centered over the wheels, or alternatively that your weight is centered, not that the two wheels track the same line or that the bars are perpendicular to the tracked line.
The string method also isn't particularly precise in that the F/R tires are different width, and besides it measures offset between where the tread starts, not at the rim. So a lot of eyeballing or ad hoc measurement techniques get used, never mind that tires aren't that precise to begin with either.
But the reality is if the tracking offset is small it makes zero difference, it's not noticeable when riding and difficult to try to measure. Perhaps in a race setting it's worth removing the tires and apply wheel spacers to where the two rims are perfectly lined up and weight evenly trimmed. For everyday riding though, not worth the bother. Unlike cars, MCs will always ride in a straight line as long as the weight is centered over the wheels.
