rack and pull engine alignment
Old Dec 16, 2023 | 02:30 PM
Evo-Wes's Avatar
Evo-Wes
Wheel alignment has two planes: linear and vertical. The adjustment using the link at the top of the motor deals with the vertical alignment of the rear wheel to the front wheel. The method of using tubing or string to the front/rear wheel is the linear alignment.
The two must not be confused as "the" wheel alignment. They are two different animals.
Old Dec 16, 2023 | 06:19 PM
Max Headflow's Avatar
Max Headflow
I would say it has one plane with horizontal and vertical components that need to be in alignment.
Old Dec 16, 2023 | 06:44 PM
Evo-Wes's Avatar
Evo-Wes
no coplanar?
(A rose by any other name.....)
Old Dec 16, 2023 | 07:50 PM
Max Headflow
no coplanar?
Coplanar is fine if you want to call it that. The points lines of interest are orthogonal. Points I was trying to make..
Old Dec 18, 2023 | 05:39 AM
Slingshot383's Avatar
Slingshot383
Which is why the Alloy Art rear engine stabilizer is a very good addition to the equation. It helps keep the rear of the engine aligned along with the forward upper stabilizer.
Old Jan 31, 2025 | 12:02 PM
MotoJockey's Avatar
MotoJockey
Reviving old thread.........
In the process of rebuilding the rear fork, (swingarm), on my 14 SGS, and while it's all apart and loose waiting for parts, I noticed a clunking from the engine while removing the rocker covers for a different repair. Found the rod ends in the front stabilizer link shot to hell. Both the rear fork and the front stabilizer have 165,000 miles on them so there WAY overdue. Been wanting to try this "Missing Link" anyhow, so figured now's a good time. Ordered it this morning and it's just coming from Sacramento, 3-1/2 hours away, so it should be here soon. Still got plenty of other things to do and parts to wait for, but once it's all back together and adjusted, I'll report back here with an update.
https://www.rackandpull.com/the-missing-link
Old Feb 2, 2025 | 11:54 PM
JamesGilbertAZ's Avatar
JamesGilbertAZ
I have the missing link waiting to go on my bike. I've been procrastinating as I am not 100% on how to adjust it yet.
Old Feb 3, 2025 | 01:46 AM
MotoJockey's Avatar
MotoJockey
There's a few videos out there, but here's one I found real quick.....
Old Feb 3, 2025 | 12:55 PM
MotoJockey's Avatar
MotoJockey
Just opened mine and it comes with printed instructions from Allen as well. I'm hoping between YouTube and his instructions, I don't have any issues. The bike is all tore apart right now so it'll be a minute before I get to test ride it.
Old Feb 3, 2025 | 06:53 PM
Two Lane Tramp's Avatar
Two Lane Tramp
I purchased one over a year ago and have had very good results. Much more even tire wear which was why I installed it.
