Handlebar change!Extensions needed?
Old May 19, 2024 | 07:48 AM
murphc13's Avatar
murphc13
Default Handlebar change!Extensions needed?
Hello people.Just looking for some opinions and experience on this.I have a new 2024 Road King Special.I am changing the handlebar to a todds cycle touring/road glide bar( i believe they call it).
The todds bar has a 12 inch rise,31/32 inches wide.
The stock bar on a RKS has a 10 inch rise but is approximately 36 inches wide.(HD claim it's 31.75 wide but it's not trust me).This topic has been covered here on this forum before about this discrepancy.
Do you guys think either turn signal extensions,clutch cable or brake line will need to be changed?Thanks in advance.
Old May 19, 2024 | 10:40 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Forget about extensions. You are just adding several more connection points that can fail.
I finally realized that Namz offers the full wiring kit in what ever length you need and they are under $50 bucks. I’ve used them on the last three handle bar installs and will never add extensions again. I just leave the original wiring in the older bars.
The last ones I bought came from Dennis Kirk. I did get a set from Revzilla once also.
Just my 2 cents worth.
Old May 19, 2024 | 11:03 AM
murphc13's Avatar
murphc13
Ok thanks fir the input but I'm more coming at it from 'do you think I'll be fine with the original parts' or need longer.HD will be fitting it.Not myself
Old May 19, 2024 | 01:24 PM
Cosmic Razorback
Clutch and brake lines should be fine.
wide glider
2014-2024 Touring Models
Mar 9, 2024 10:43 AM
beanoboy
Aug 8, 2020 06:38 AM
Dargdb2012
Apr 7, 2019 03:50 PM
Seadweller
Dec 1, 2010 09:03 AM
Roadrider18
General Topics/Tech Tips
Oct 25, 2006 06:37 PM
