Kraus EZ shift
Old Nov 22, 2025 | 05:16 PM
  #51
Max Headflow's Avatar
Max Headflow
Originally Posted by Robertbc3141
Everyone has their own routine and way of doing things.
I'm sure that works for you.
For me at a stop I have my left foot down and my right foot on the brake, I don't know how I would shift from neutral into first to get going.
Now you know..
Old Nov 26, 2025 | 09:58 PM
  #52
Hoyt 1911A1's Avatar
Hoyt 1911A1
As far as the hydraulic vs. clutch cable gig I have always preferred cable over hydraulic. I've had two bikes with hydraulic clutches and hated both of them. Engagement band was too dang narrow. I really liked it when Harley went back to cable clutches. Had a return hole get plugged in a clutch master cylinder one time and caused a heck of a problem. Also had a slave cylinder get gunked up and caused a bunch of grief. None of that is an issue with a cable clutch.
That being said, when Harley did go back to the cable clutch they jacklegged it. Instead of a cable going from the lever to the tranny, they used two cables joined together. It just ain't as smooth as the single cable bikes. It's not terrible, but it's pretty jerky unless you keep the cable pretty tight, which I don't like. I like a little slack in my clutch levers.
Leave it to Harley to screw up something so simple and time tested.
Old Nov 26, 2025 | 10:07 PM
  #53
MotoJockey's Avatar
MotoJockey
My new to me 2022 SGS has the new cable set up and I don't care for it. Do the have a full length cable swap out upgrade yet? Of all the cable and hydraulic clutch's on all the different bikes I've had, I dislike this one the most........
Old Nov 26, 2025 | 10:18 PM
  #54
skills's Avatar
skills
Originally Posted by Goose_NC
You could have simply drilled a hole 3/4 of an inch down on the stock front lever and not spent $15 on a part that could break.
You're going the wrong direction when you make the pivot point closer to the shifter shaft. Isn't that why the aftermarket arm is longer in the first place?
Old Nov 27, 2025 | 08:15 AM
  #55
Cold Forged's Avatar
Cold Forged
There are two different approaches to improving shifting: Shorter Front Arm and Longer Rear Arm.
The Thrashin EZ Shift Front Arm is shorter and makes shifting approximately 25% easier (according to Thrashin's claims...see their video about the reduction in torque required to shift)...
Think of why the hill climbing front sprockets on a mountain bike are smaller...this makes it easier to pedal uphill.
Conversely, the larger rear sprockets are the lower gears...which is why the Kraus EZ shifter is an extension to lengthen the rear arm.
Old Nov 27, 2025 | 09:29 AM
  #56
CameraMan's Avatar
CameraMan
I have written about this somewhere else, I don’t recall. My 06 Ultra Classic can’t find N when at operating temp to save my life. I had my tech re- readjust it and called it fixed. If the bike’s cold or off, I can get it into neutral ok. Not hot. Fluid level checks out, etc. Heel/toe shifter checks out.
I’m likely selling it anyway, not for this reason in particular, but it’d be nice if it did operate properly. One of those dohickeys would seem to be a legit fix.
More reviews?
Old Nov 27, 2025 | 10:30 AM
  #57
Robertbc3141's Avatar
Robertbc3141
More reviews?
That's interesting - it's interesting the way different people ride. As you say it's easy to get neutral when it's cold, but that's the only time I ever shift into neutral - to start it.
It will sometimes lurch forward a bit if you try to start it with just the clutch pulled in and in gear so I don't do that.
I never shift to neutral on a ride - city stop and go or a long ride. Im in first at a traffic light.
This seems to be the exception as I read a lot of people shift into neutral during their rides - stops or I don't know what reason.
So I wouldn't even know if mine was hard to shift into neutral when it's hot.
Other than when I bought my bike and was going through the receipts of the previous owner there was a lot of "owner reports it hard to find neutral" notation in every oil change he had.
So probably so.
Riding a different way than he did I've never noticed it.
But I have noticed it's even easier to find neutral with my newly installed heel shifter.
I have an 08 Ultra Classic.
Old Nov 27, 2025 | 12:13 PM
  #58
deadbroke's Avatar
deadbroke
Had this same issue with my previous RK ,a 2008. Couldn't find neutral . Don't know if my new to me,2022 will be the same,just got it and haven't ridden it but off the trailer. I love Harleys but compared to the Triumph Bonneville I had,the shifting is like a farm tractor.
Old Nov 27, 2025 | 01:41 PM
  #59
skills's Avatar
skills
The Thrashin EZ Shift Front Arm is shorter and makes shifting approximately 25% easier (according to Thrashin's claims...see their video about the reduction in torque required to shift)...https://www.youtube.com/watch?v=RD1mQUo8LOE
​​​​​​Shorter Front Arm and Longer Rear Arm.
This makes more sense
Old Nov 27, 2025 | 01:51 PM
  #60
Max Headflow
More reviews?
The 5 speeds are the much better than the 6s. Especially the 2001-up trannies.. You got something wrong with your clutch..
