2014 Rushmore High OP
Old Mar 7, 2014 | 08:43 AM
Bricklayer's Avatar
Bricklayer
Default 2014 Rushmore High OP
What exactly makes the new Rushmore 103's high out put? Other than the higher flo air intake what makes it any different than a standard 103. Did they put a different cam in the Rushmores? And if the new air intake is a higher flowing system, why would you need to swap it out when doing a stage 1. Wouldn't maybe replacing stock air cleaner with a K&N be enough?
Have asked these questions at the dealership but haven't gotten any real concrete answers, so I thought I would come here and ask the experts. Any ideas?
Old Mar 7, 2014 | 09:22 AM
candave650's Avatar
candave650
Wow the dealership doesn't know??
Get a new dealer quick
Rushmore engines have a more aggressive cam check out HD website
The new AC flows more air and is probably OK for stage1
Old Mar 7, 2014 | 09:29 AM
GlidingJoe's Avatar
GlidingJoe
The cam's in the new 103 are different than previous 103's
2013 cams Lift int/exh .484/484 dur @.053 int/exh 198/220
2014 cams Lift int/exh .484/484 dur @.053 int/exh 213/233
SE-255 cams Lift int/exh .556/556 dur @.053 int/exh 211/235
As for the A/C, there currently is not a K&N replacement element for the new style cleaner. The current element certainly ads more air than previous models but will still be restrictive when doing an exhaust and tuner for stage 1
Old Mar 7, 2014 | 09:58 AM
Bricklayer's Avatar
Bricklayer
Thanks guys, I knew I came to the right place.
Old Mar 7, 2014 | 10:09 AM
GCSuper's Avatar
GCSuper
Compression is higher also, thus the need for 93 octane fuel.
Old Mar 7, 2014 | 10:47 AM
Gunnysgt's Avatar
Gunnysgt
93 octane?? I'm pretty sure my'14 owners manual still says 91 is fine. What page is that on?? Don't really need the 91 in the colder weather, the 91 shows up more for warm weather riding. I"ve run 89 quite a bit with no issues in the colder weather. No Pinging
Old Mar 7, 2014 | 11:44 AM
oakmossy's Avatar
oakmossy
to me 91 is high octane. 87 is regular here in the lone star state.
Old Mar 7, 2014 | 11:47 AM
Clayvis's Avatar
Clayvis
You got it all wrong. The High Output refers to the money flowing out of your wallet to buy one! hee hee...think I'm a bit jealous? naaawww!
Old Mar 7, 2014 | 12:15 PM
Bricklayer's Avatar
Bricklayer
That's a fact Jack!!!
Old Mar 7, 2014 | 12:18 PM
Bricklayer's Avatar
Bricklayer
We have 93 around here but many places don't.
