Fork lock?
Old Apr 3, 2014 | 05:18 PM
TcHunter's Avatar
TcHunter
Default Fork lock?
I have a 2014 FLHXS, the other day I locked my forks, when I came back to unlock them the ignition switch would not turn to run/accessories , I had to turn my handlebars/ forks to the right about two or three inches to the right in order to turn the ignition switch to run. Now I did not have that problem on my 2013. Does this sound normal? I am going down to the dealer this weekend I will also talk to them about this. I just wanted to know if anyone else has experience this, or am I doing something wrong. Thanks for the feedback.
Old Apr 3, 2014 | 06:25 PM
LeeH's Avatar
LeeH
Mine does the same thing. I thought it might be because the locking mechanism is a little tighter fit than the older models.
Old Apr 3, 2014 | 06:48 PM
cycle7447's Avatar
cycle7447
Community Influencer
If you were able to turn the switch - it does not seem that you really locked your folks. To unlock them, you need the key.
Old Apr 3, 2014 | 07:46 PM
TcHunter's Avatar
TcHunter
Used key to lock it, once locked I could not turn ignition switch or bars so I know it locks. and used key to unlock, that is when I noticed that I could not turn ignition switch with out moving the handle bars.
Thanks.
Old Apr 3, 2014 | 07:59 PM
T_Dogg80's Avatar
T_Dogg80
Totally normal.
Old Apr 3, 2014 | 10:19 PM
dgreen1069's Avatar
dgreen1069
Originally Posted by T_Dogg80
Totally normal.
Some cars are the same way....you can't turn the ignition key without taking the pressure off the steering wheel lock.
Old Apr 3, 2014 | 10:59 PM
mickeylynn's Avatar
mickeylynn
My 2012 Fatboy was like that. It had to be in just the right spot to lock/unlock. Ive never had to figit with my SGS though
Old Apr 4, 2014 | 03:44 AM
SoZoomMe's Avatar
SoZoomMe
My trouble is locking and unlocking. Most of the time the key is really hard to turn; other times there is no problem. No problem turning the switch itself.
Old Apr 4, 2014 | 05:16 AM
LeeH's Avatar
LeeH
Usually if you pull the bars to one side or the other, its a lot easier to lock/unlock.
When you engage the lock, the locking pin is pushed downward into a slot on the frame. If the locking pin is pushed up tight on either side of the slot, there is a lot of resistance to overcome. By moving the handlebars so the pin isn't up tight against the side of the locking slot, you get rid of the resistance...
Old Apr 4, 2014 | 11:52 AM
OldPhat's Avatar
OldPhat
I to had a lock problem, not locking and Unlocking when it was Locked, I feel it is due to being new.
Ever thing works better the more miles you put on the Bike.
