Inquiry on expected dyno numbers...
Old Apr 10, 2014 | 02:51 PM
flexx220022's Avatar
flexx220022
Default Inquiry on expected dyno numbers...
I've recently installed Stage 1 on my 14' SGS. I went with the V&H Power Duals and the V&H Hi Output mufflers. Now the bike is being taken to the dealer this weekend for the install of the SEPST. I'm just curious what type of increase in HP & Torque should I expect to see with this setup. Thanks in advance for any input of feedback.
Old Apr 10, 2014 | 03:31 PM
bedowinn's Avatar
bedowinn
Which Air cleaner setup?
I would guess around 75 to 80 hp and 100 ft/lbs of torque.
All dynos are different so your mileage will vary.
Old Apr 10, 2014 | 03:36 PM
SoZoomMe's Avatar
SoZoomMe
The Hi-Outputs are very free flowing. This is from their website:
Designed specifically to address the needs of tuned motors built for high horsepower applications, (hi compression, large displacement, big cams). Every aspect of the Hi-Output slip-on's design is singularly focused to yield maximum horsepower by improving the volumetric efficiency of heavily modified engines as well as stock.
This is one of the reasons I didn't use them when I did my Stage IV. Not enough back pressure.
Not sure what numbers you will see. May turn out good.
Old Apr 10, 2014 | 04:02 PM
flexx220022
I went with the Screamin Eagle Agitator Extreme Billet "Air Cleaner" Kit
Old Apr 10, 2014 | 04:40 PM
Bagged Out's Avatar
Bagged Out
Does anyone know the real world rear wheel numbers for the 2014 103 stocker?
I am adding SEPST, V&H pro pipe and Arlen Ness inverted A/C but not doing a dyno.
Wondering what my baseline is?
Old Apr 10, 2014 | 04:46 PM
Smiff's Avatar
Smiff
I got a 12 hp increase / 87 hp 100 tq
Bagged Out
Feb 2, 2021 11:46 PM
drew4jan
Apr 5, 2012 08:09 PM
alauhog
Dec 19, 2011 07:42 AM
bbach
Oct 24, 2010 04:09 PM
luvmyflhtcui
Aug 17, 2006 11:02 PM
