air shocks
Old Apr 15, 2014 | 10:18 AM
bba's Avatar
bba
Default air shocks
which is the best way to pump up the air shocks with a hand pump or at air machine at the gaz statiion
Old Apr 15, 2014 | 10:27 AM
AXL'14FLHTK's Avatar
AXL'14FLHTK
You can only use a hand pump to adjust your suspension, you can purchase one from your dealer.
Old Apr 15, 2014 | 10:33 AM
jcapps's Avatar
jcapps
Do not use a compressor!!!!!!!!!!!!!
Hand pump only, you can use a basketball pump but better off with a pump from the dealer with a gauge
Old Apr 15, 2014 | 11:03 AM
Shep68's Avatar
Shep68
Hmm. I have been using a compressor, but keep the psi turned way down so as not to blow the shocks apart. Give it short bursts until I reach about 35. Hand pump would be handy and portable though.
Old Apr 15, 2014 | 11:17 AM
bba's Avatar
bba
hand pump it is
thanks
bba
Old Apr 15, 2014 | 11:23 AM
rob_low0228's Avatar
rob_low0228
hand pump, but for some reason mine doesn't really work well... is there a trick to getting it to work?
i'll screw it on, get the reading, pump. like 1/4 pump it pegs the gauge.... something aint' right...
Old Apr 15, 2014 | 02:31 PM
WaucondaRider's Avatar
WaucondaRider
I picked one up cheap on eBay: http://www.ebay.com/itm/Harley-David...d76174&vxp=mtr
Old Apr 15, 2014 | 05:20 PM
Hammz's Avatar
Hammz
What pump are you using? If it's the H-D suspension pump or similar Progressive suspension pump, then you've got the right pump. When attaching those pumps, you need to screw them on all the way. When properly attached, the gauge will read the current pressure in the shocks. You can then add pressure by pumping or relieve pressure with the bleed button. After proper adjustment, the pump can be be unscrewed from the fitting w/o losing shock pressure.
Again, the key here is to make sure the screw connection is fully tightened.
Hope this helps.
Old Apr 15, 2014 | 05:27 PM
Vincewd's Avatar
Vincewd
I have a HD hand pump with gauge, it sucks and I hate the stupid thing. I use my air compressor, Just short burst s of air.
Old Apr 15, 2014 | 05:36 PM
DeadShort's Avatar
DeadShort
I'm no genious when it comes to air shocks but I would figure that if I used a regulator and a flow control valve I could use a compressor to fill the shocks. I could very well be wrong though.
