Read this if you are installing HD heated grips
Old Sep 18, 2017 | 02:20 PM
BB59's Avatar
BB59
Originally Posted by Gunneredwards
what does the orange and white wire do? didnt hook it up and the grips dont seem to heat up.
dan
The orange/white wire is a switched hot wire from the Accessory circuit
Old Sep 24, 2017 | 07:44 AM
dannyb-SGS's Avatar
dannyb-SGS
I had the same problem on my 2016 FLHXS while doing my Harley heated grips. I had done my research before starting as I was totally confused after reading the useless instructions. I already knew of the problem so I went to the harley dealer with the part numbers for the connectors and female ends and had them make me a 3" double female jumper to mate the 2 male ends together. I didnt want to cut the original connector in case it was needed for something else down the road. Im glad I did the install myself as I found the power lead wire going into the inline fuse holder wasnt even crimped properly. They had only crimped the insulation and not the wire into the holder. So when I pulled on the wire it came right out of the feed in side of the inline fuse holder. That would of been a great problem down the road when the grips worked intermittently or not at all. So I soldered both sides of the inline fuse.
Hatrick
May 2, 2017 06:04 AM
eglide_rider
2014-2024 Touring Models
Feb 10, 2016 10:53 PM
Lsc8
Jan 3, 2016 07:15 AM
DonCMcC
Apr 4, 2015 06:53 PM
anonymous_1
Sep 20, 2013 07:00 AM
