Bluetooth Stopped Working
Old May 4, 2014 | 03:04 PM
2WheelGlider's Avatar
2WheelGlider
Default Bluetooth Stopped Working
At 3k miles, had first real problem with infotainment system today. Bluetooth does absolutely nothing. Go to setup and move to Bluetooth and all options are greyed out. Can not select anything, no Bluetooth symbol on bottom of screen either. Phone has been paired since day one and all of a sudden today I can't do or select anything Bluetooth.
Any ideas?
Old May 4, 2014 | 03:16 PM
rmc115's Avatar
rmc115
reboot the bike (pull maxi fuse) and reboot the phone. that fixes most bluetooth issues. Mike
Old May 4, 2014 | 05:06 PM
spr0k3t's Avatar
spr0k3t
I had to unpair my phone a couple times. Nothing major. Pulling the main fuse should do the trick though.
Old Jul 7, 2019 | 06:43 PM
Robbie Snyder's Avatar
Robbie Snyder
Stage II
Default Ever figure this out?
Any ideas?
Did you ever get to the bottom of this problem have a buddy with the same problem?
Old Jul 8, 2019 | 07:35 PM
Hammz's Avatar
Hammz
5 year old post you commented on. You need help w/BT?
Old Jul 8, 2019 | 07:59 PM
Robbie Snyder
Stage II
Default Bt not working
Yes my buddy's is doing the same thing he described was paired to the phone before worked fine then it was t paired one day tried to repair it for him but when I go to the bluetooth screen all the buttons are grey and I cant access anything
Old Jul 9, 2019 | 12:40 AM
Hammz's Avatar
Hammz
Which BT screen is grayed out? I guess that really doesn't matter. Sounds like it needs to be repaired.
  • Go to HOME>SETUP>BLUETOOTH SETUP
  • check the BLUETOOTH box to toggle on/off (on is a check in the small box on the left of that bar)
  • click List Paired Devices
  • only entry choice should be Add New Device
    • if there are any devices listed, delete them
      • select the device
        • select Delete Pairing
        • select OK
  • delete phone's BT pairing to the bike, place phone into BT on/pairing discovery
  • select Add New Device
  • phone should appear on screen, select it & confirm pairing
Old Jul 11, 2019 | 12:35 PM
hog95023's Avatar
hog95023
I had to do what hammz stated on my 2019 bike the day after I bought it. been working fine since. paired it in dealer lot, next morning no Bluetooth. deleted the connection, paired again and fine since. but its only been 5 days since
Old Jul 11, 2019 | 03:24 PM
cycle7447's Avatar
cycle7447
Community Influencer
I know that guy Hammz- knows his stud... he is a real HAM
sorry - I had to do it.
Old Jul 16, 2019 | 09:10 PM
Joseph Nicholson's Avatar
Joseph Nicholson
1st Gear
That only works if your buttons aren’t grey and unable to be selected.
      • select the device
        • select OK
