Passing lamps
Old Jun 9, 2014 | 06:56 AM
motorcycleboy's Avatar
motorcycleboy
Default Passing lamps
Had the fairings off this weekend, inner, outer, and switch- for some handlebar adjustment and touch-up painting. After reassembly the passing lamps dont come on, and the switch is not on (no light). Headlight works fine.
Cant find or imagine what is wrong, its 3 plugs, 1 at each lamp, 1 at the switch. I did however, turn on the ignition for headlight adjustment before the lamps were reinstalled. Is it possible the mysterious (to me) canbus gods "learned" that the lamps werent there? Or does it have to be something more simple ie: bad contact/connection?
If I sound like I dont know what I'm talking about... Well dont be surprised.
Old Jun 9, 2014 | 07:26 AM
hojones's Avatar
hojones
You have probably left a connector unplugged. If they worked before you did your work it's probably on your end.
Old Jun 9, 2014 | 07:32 AM
Merri1's Avatar
Merri1
check the fuse. I installed a pigtail for heated vest. and then the passing lamps didn't work. It was as simple as changing the fuse.
Old Jun 9, 2014 | 07:52 AM
motorcycleboy
Yeah, its gotta be that simple right? Just ran out of time before I could check fuses and recheck the connectors, but I have NO doubt that the problem is from my end.
Old Jun 9, 2014 | 11:09 AM
motorcycleboy
Are the fuses still under the left side cover... and are they marked?
Old Jun 9, 2014 | 01:32 PM
roqnrod's Avatar
roqnrod
Probably not the reason but I had the same problem and then realized my high beams were on thus the passing lamps turn off.
Old Jun 9, 2014 | 01:57 PM
motorcycleboy
Ha! Nope, checked that, and made sure the high beam was working as well.
Old Jun 9, 2014 | 09:50 PM
Hammz's Avatar
Hammz
Yes. Yes.
Windseeker
Jun 12, 2019 06:37 PM
r1cochet
Electrical/Lighting/Alarm
Jul 27, 2014 10:06 AM
chidiver
Mar 2, 2010 06:04 PM
Coast_Man
Oct 10, 2009 01:32 PM
r
Nov 11, 2005 02:59 AM
