1k service list help
Old Jul 25, 2014 | 03:58 PM
oakspeed's Avatar
oakspeed
Default 1k service list help
i need to do a 1k service on my 14 street glide. im still waiting for a service book to get here. can anyone send me a bullet point list of the items that i need to check. i know i have to change all 3 oils, and a general bolt torque check, but would appreciate a list if anyone has one.
thanks.
Old Jul 25, 2014 | 04:33 PM
davessworks's Avatar
davessworks
The list should be in your owners manual (I believe). Also here:
https://www.harley-davidson.com/cont...schedules.html
Old Jul 25, 2014 | 04:43 PM
SafetyMan's Avatar
SafetyMan
Electrical equipment and switches: Check operation
Front tire: Check pressure, inspect tread
Front brake fluid: Inspect sight glass
Clutch fluid: Inspect sight glass
Reservoir cover screw: fr. brake and hyd. clutch; Check torque
Hand control fasteners: Check switch housing screw torque; Check clutch lever handlebar clamp screw torque; Check master cylinder handlebar clamp screw torque
Engine oil and filter: Replace
Engine coolant: Check freeze point, inspect for leaks; Clean radiators
Primary Chaincase Lubricant: Replace
Transmission lubricant: Replace
Right front engine mount end cap screws: Check torque
Engine mount to front crankcase screws: Check torque
Oil lines and brake lines: Inspect for leaks, contact or abrasion
Fuel lines and fittings: Inspect for leaks, contact or abrasion
Rear brake fluid: Inspect sight glass
Rear brake reservoir cover screws: Check torque
Brake pads and discs: Inspect for wear
Front axle nut: Check torque
Jiffy stand: Inspect and lubricate
Brake and clutch controls: Check, adjust and lubricate with HARLEY LUBE
Rear tire: Check pressure, inspect tread
Drive belt and sprockets: Inspect, adjust belt
Rear axle nut: Check torque
Air Suspension: Check presssure, operation and leakage
Exhaust system: Inspect for leaks, cracks and loose or missing fasteners
Fuel door: Lubricate hinge and latch with HARLEY LUBE
Road test: Verify component and system functions
Old Jul 25, 2014 | 04:44 PM
oakspeed's Avatar
oakspeed
Doh!!! Your right. The to-do list is in the owners handbook. I really should pay attention. Thanks.
Old Jul 25, 2014 | 04:46 PM
oakspeed's Avatar
oakspeed
Many thanks for taking the time to help an idiot.
Old Jul 25, 2014 | 05:49 PM
davessworks
  1. Originally Posted by oakspeed
Nonsense - no such thing as a stupid question, even if the answer is staring you in the face ;-)
Jchaiyo
2014-2024 Touring Models
13
Nov 21, 2017 10:33 AM
dchoran
Jun 23, 2009 09:00 PM
BoomSoon
Aug 8, 2008 08:34 AM
hockey8787
Apr 29, 2008 09:03 PM
jmbear328
Apr 17, 2006 02:29 PM
