SGS suspension
Old Jul 28, 2014 | 09:53 PM
TXCobra's Avatar
TXCobra
Originally Posted by 2014streetglide
Thanks for all the info on the trees! I don't think I'll be going that route. Txcobra, do you bottom out? I had sent burley an email asking about their shocks. Their reply was the street glide has 11 1/2" shock and I'd be lowering it to 10" and I'd bottom out and rub the tire.
I've never bottomed out. There is a bump stop that will prevent it. But I also ride 1 up almost 100% of the time.
Old Jul 28, 2014 | 09:59 PM
TXCobra's Avatar
TXCobra
And I agree with everyone here, I will NEVER mess with the front forks...they are staying as the MoCo shipped them.
Old Jul 29, 2014 | 08:17 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by LilWick
I love how those that have not done...talk about how it is. I put air on the rear and the tire did not rub. Dropped all the way down. Lowered the front by sliding the forks up in the trees...didn't hit or damage anything...installed 2 inch lowering springs in forks....1000 miles later, handles great, no contact. Not even close.
When you put lowering springs you increase the top out spring length reducing the stroke not the length of the fork & slider. When you push your fork up into the triple tree I showed you what must happen with full spring compression. The measurements are just that. It is your bike and you do with it what you like, I do care one bit.
Old Jul 29, 2014 | 08:22 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Fast harley, if you read my first post, I did measure it for myself. Although I didn't use a caliper, I used exactly what was in your pics you posted, a tape measure. I was asking advice to make sure there wasn't something weird I had to measure to get the 11 1/2" that the dealers and burley had stated to me. But thanks for your input.
Now I know that I can use a lower seat or shocks or a combination of the two it get where I want to be.
Custom96, which seat did you go with to get lower?
You need to learn how to read a caliper as the OEM air shocks are 12" or 13". I am not going to post a picture of this and waste my time as I have measured them myself.
Old Jul 29, 2014 | 08:34 AM
Hammz's Avatar
Hammz
If you raise the tubes in the trees far enough, you WILL, sooner or later, experience contact interference with moving (sprung) parts vs fixed (unsprung) parts. If you don't believe this, go ahead & move them up 2+ inches & ride some rough roads. You'll find out 1st hand what Howard's saying is FACT despite what you may think.
Old Jul 29, 2014 | 08:49 AM
2014streetglide's Avatar
2014streetglide
fastharley, the street glide special does not have OEM air shocks. They come with the new OEM hand adjustable shocks. So before you go judging me or anyone else about buying a caliper and reading one, please understand that you are on a totally different shock than the one I'm referring to. Again thanks for your input and the pics and drawings you have showed me and us. You seem very knowledgeable, but I'm thinking we are referring to different shocks.
Old Nov 24, 2015 | 06:14 PM
bill_1202's Avatar
bill_1202
Originally Posted by Webo
The shocks are 12" on the Street Glides. You might look at a different seat to lower you, they ware usually lower and narrower so it's easier to get your feet on the ground. If you lower it with the suspension it's most likely to ride stiffer than it does now.
+1 on this. Check out Mean City Cycles. You send them your seat and they will fit it for you and ship it back to you. Give them a call? I would try modding your seat first. Then, I would drop the front with Olin's or Progressives. The last mod I would do is the back. SG shocks are already lowered and short and you might end up really unhappy with a hard ride.
Old Nov 24, 2015 | 09:19 PM
Uncle Paul's Avatar
Uncle Paul
Rushmore Street Glides have come with 3 different rear shocks. Might be the issue here.
In 14 the standard SG had air adjustables and SGS had first generation premium hand adjustable shocks.
In 15 SGS changed the model number and have 2nd generation premium hand adjustable shocks. (Believe change was to add comfort for lighter riders)
All are called 12" or short shocks, compared to the other standard or 13"
More important than the length of the shock is the length of the shock after the rider sits on the bike (sag). A firm spring will sit you higher than a soft of variable spring.
Howard knows suspensions. If you have a specific question give him a call, and he will listen to your needs and give you the information necessary to get the optimum suspension for your bike. Best service and more than competitive prices too.
Old Nov 25, 2015 | 10:27 AM
bsteinb's Avatar
bsteinb
Stage I
+1 on Mean City Super Narrow! Not only will it be lower, the seat will be comfortable.
burnafatty
Dec 22, 2017 12:32 PM
onthelo
2014-2024 Touring Models
34
Nov 21, 2014 11:45 AM
Ventana
Jul 11, 2011 10:10 PM
jaysonL
Mar 18, 2010 03:52 PM
policepop
Dec 31, 2006 12:15 AM
