So I'm looking at the instructions for the Boom! Amp and they say that it'll add as much as 8 amps of additional load at full volume.
Quick calculation. Watts = volts x amps
12volts x 8 amps = 96 watts. Amp states it's 75w x 4.
Now a watt is a watt. There's no getting around that. It's a joule per second. A unit of power ie rate of energy consumption.
So, something don't add up . . .
My best guess is that the 75 watt claim simply applies to peak power output, not sustained. Further, I think this practice is common in the audio industry, but it's a little fishy.
I've always had a bit of a problem with audio wattage claims.
Is it actually 12 volts? there sure is hell isn't 12 volts going to the speakers.
The radio may draw 12 volts for power but that 12 volts can't make it all the way through the radio to the speakers, there is some inefficiency, which produces heat and that alone reduces the wattage.
The amp cannot put out more power than it consumes. The amp consumes 12volts x 8amps ie 96 watts.
You are forgetting that internally You are amplifying a signal and the power output of that amplified signal can be greater than the current drawn to power the amplifier.
No it can't! That's physically impossible.
The total power out of the amplifier cannot exceed the total power in to the amplifier. That would defy the laws of physics. Furthermore the amplifier inputs are line inputs, not the amplified signals that would go from the head unit to the speakers without using the add on amplifier - so there's no power to speak of coming from the head unit.
