57H cams and Power vision- who's running them?
Old Aug 28, 2014 | 04:34 PM
RK14SGS's Avatar
RK14SGS
Default 57H cams and Power vision- who's running them?
Who's running the 57H cams in their 2014 and using a power vision? I have done the stage one AC, decatted headpipe, and have monster rounds. 57H cams are on the way. I can autotune, but was mostly curious about the timing tables. Thanks in advance!
Old Aug 29, 2014 | 12:50 AM
ke5rbd's Avatar
ke5rbd
You are in luck. Did this one today and it has a very good timing map in it. Should work just fine. If you have a problem with it let me know. I would run it some first before trying to autotune. That way you will be able to tell if you are helping or hurting. With cams the autotune is not too good below 2000 rpms. Good luck on the install.
Old Aug 29, 2014 | 07:32 AM
RK14SGS's Avatar
RK14SGS
Thanks!!
BlkLine12
Sep 8, 2014 10:53 AM
ajmilberg
May 28, 2014 02:16 PM
ajmilberg
Dec 12, 2013 11:21 AM
ncdan
Dec 2, 2009 08:06 AM
fj4069
Exhaust System Topics
Mar 17, 2008 07:10 AM
