CVO Dash Trim Install
Old Sep 5, 2014 | 08:03 AM
CapeGlide's Avatar
CapeGlide
Default CVO Dash Trim Install
Finally got the dash trim (part # 61400122A) yesterday and installed it. Looks great, the flash on the camera gives it more of a chrome look, however it's more of a black finish..love it.
For those who had issues installing theirs, this is how I did it. Used some painters tape to tack in place, drew a line with a sharpie to mark the location, cut the tape with a utility knife, removed backing and starting at the bottom lining up the lines, gently moved into place. Worked great.
Attached Thumbnails CVO Dash Trim Install-dash-1.jpg   CVO Dash Trim Install-dash-2.jpg   CVO Dash Trim Install-dash-3.jpg
Old Sep 5, 2014 | 09:48 AM
fmgsr's Avatar
fmgsr
Nice job, I ordered mine last night. Did you also see the ones listed as left and right. I'm assuming it's for next to radio. They were cheap, so I ordered them also.
Old Sep 5, 2014 | 09:58 AM
scottt's Avatar
scottt
Great job!!! FYI, Harley has discontinued the 14 CVO dash trim that you installed. The 15 CVO ultra's have a different trim panel.
Old Sep 5, 2014 | 10:37 AM
CapeGlide's Avatar
CapeGlide
Are you sure its discontinued? I know the dealer contacted me saying they were having a hard time getting it, then called back to say the part # was changed and the order went through.
Old Sep 5, 2014 | 10:46 AM
fmgsr's Avatar
fmgsr
Google it, a lot of dealers have it.
Old Sep 5, 2014 | 11:08 AM
Nickblink's Avatar
Nickblink
Hello,
Can you please describe more details about the left and right? And what is the part number please.
Old Sep 5, 2014 | 11:20 AM
fmgsr's Avatar
fmgsr
Qty. Part Number Product Name Price Line Total
1 61400063 TRIM inner fairing, left | ALL - TRIM inner fairing, left | ALL n $9.00
1 61400064 TRIM inner fairing, right | ALL - TRIM inner fairing, right | ALL $9.00
1 61400122 TRIM | ALL - TRIM | ALL $60.00
Old Sep 5, 2014 | 11:52 AM
Nickblink's Avatar
Nickblink
The 61400063 & 64 are the rubber seals between the inner and outer fairing. Why did you need that?
Old Sep 5, 2014 | 03:33 PM
fmgsr's Avatar
fmgsr
It doesn't say rubber seal, it says inner right and left trim.
I found a diagram, your correct. I put in a request to correct
My order.
Thank You
Old Sep 5, 2014 | 03:36 PM
scottt's Avatar
scottt
Yes, I am positive. I wonder if your dealer ordered the 15 CVO trim panel. The only way you can secure the 14 CVO dash trim panel is to find a dealer with one in stock. Your dealer can provide a list of dealers with part in stock.
Good luck
