lets see the Apes!
Old Oct 28, 2014 | 03:48 PM
  #121
sixshooter's Avatar
sixshooter
If I recall from doing mine, I fed the throttle wiring and control wiring in from the bottom as one, taped together, and once the control wiring was where I needed it, cut the tape and situated the throttle wiring where I needed it, slid the throttle mech in and reached through the machined slot and plugged the throttle mech harness into the pigtail already in. If your plug is sitting right on the peak, just pull it out a bit towards the bar end and leave some slack up top. Better to have the wiring too loose than too tight. What worked well for me was bending a "U" in the end of a coat hanger and using that from the bar end slot to push the wiring away from the sharp bend internally while pushing from the bottom, then once everything was situated, find something to stuff in the bottom slot around the wiring to keep it held in place.
Old Oct 28, 2014 | 05:14 PM
  #122
DD Dont's Avatar
DD Dont
I ended up ripping apart one of the connectors for the TBW, so now the plan is to cut the connectors off and solder everything together.
What a PITA so far, I hope the end result is worth it!
sixshooter, did you leave the vinyl "sleeve" on your harnesses or not? I only managed to get everything in place and moving easier once I cut them off. Although I did like the idea of extra abrasion resistance.
Old Oct 28, 2014 | 05:26 PM
  #123
sixshooter's Avatar
sixshooter
I can't remember if I did or not. The wiring was a bitch, but I got mine eventually situated after a lot of cursing and beer drinking. If the covering you're talking about fell about where the top bend in the bar is, I'd have done everything I could to keep it on.
Old Oct 28, 2014 | 08:01 PM
  #124
DD Dont's Avatar
DD Dont
I had to run to Radio Shack and grab some shrink wrap which was good because I was going to beat these bars into the concrete in short order.
Now I just need to find the right diagram in the service manual to make sure that the red, white, and black (yellow harness), and the red, white, and black (black harness) get soldered to the correct color wire on the TBW harness.
That will be for tomorrow though.
Old Oct 29, 2014 | 02:38 AM
  #125
Spazz's Avatar
Spazz
Originally Posted by DD Dont
So, no matter what I try, I cant get the right side of the bars wired internally.
Mostly because the connectors for the TWB assembly wish to reside right in the "peak" of the bars.
If I have the control harness inside the bar, I cant get the TBW harness to push back down once I connect the TBW assembly.
If I do it without the control harness installed, I can get the TBW assembly seated, but then cannot get the control harness back through.
WTF
What worked for me to get the connectors over the peak was a plastic coat hanger that I cut just AFTER the bend... leaving a small upward piece... I beveled that upward piece and put the TBW harness on top of the bevel and slid it inside the bar to the peak... then used it to push and guide over the peak... worked great for me.
Also.. if you haven't got any... get conduit lube from electric supply house.... KY FOR WIRING.... use it all the time at work
Old Oct 29, 2014 | 03:12 PM
  #126
DD Dont's Avatar
DD Dont
Got them on and took it for a 25 miles test ride.
Absolutely worth the effort and frustration so far!
I feel like I have more control in corners and seems better on the back.
Definitely colder on the hands in 50 degree weather. FISTS IN THE AIR!
Will post a few pics later.
Thanks for all the help!
Old Oct 30, 2014 | 08:22 AM
  #127
DD Dont's Avatar
DD Dont
12" MBB
Old Oct 30, 2014 | 06:30 PM
  #128
JiXeR's Avatar
JiXeR
looks damn good man! can't wait for saturday, got a ride planned, then a buddy is coming over to help me install my new primeapes. soooooooo looking forward to it. just hope everything goes smooth.
Old Nov 1, 2014 | 09:08 PM
  #129
dgdamore's Avatar
dgdamore
Finally installed mine today. Fishing the all the wires was a real bitch, TWB, switch wires and heated grips. All in, it took me about 8.5 hrs (including a lunch break and clean up), working at an easy pace.
I still am not sure what my permanent solution for mirrors will be. (I don't think I like the way my stock mirrors look on the 12s. A little high for my taste, and I don't care for the under the bar mirror look either. Anyone what's involved in mounting fairing mounted mirrors on a CVO? (There is no holes in the fairing for them.)
I also need to do a little additional brake/clutch line routing to clean them up a bit.
Old Nov 3, 2014 | 09:15 AM
  #130
JiXeR's Avatar
JiXeR
WOOT! 4 hour install! that went smooth as a baby's ***. i'll post some pics when i wash my bike. lol. it's a bit dirty from this weekend.
