lets see the Apes!
Old Feb 20, 2016 | 04:22 PM
  #401
sixshooter's Avatar
sixshooter
Who's replaced their stock 1 piece top handlebar clamp setup for a better holding clamp and who'd you use? Over the last two years, I've had my bars slip twice and it's a pain in the *** taking it apart, reset, and put 1/2 a turn on the bolts. I've had issues in the past with bushing changes causing my inner fairing to not fit down properly, so figured I'd ask around to see what you guys who've changed the bushing and entire clamp on your rushmores went with. Thanks.
Old Feb 26, 2016 | 03:23 PM
  #402
autonoz's Avatar
autonoz
Stage IV
Originally Posted by redrocker
12" LA Choppers. Here is a good before and after if anyone wants to see a height comparison to the stock bars. I am 6' tall and the bars are just below shoulder height. Very comfortable. When this 10 inches of snow melts, I will be able to give it a longer ride. I also changed out the brake and clutch lines because I did not want the black lines.
Are you saying the stock lines wuld have fit?
Old Feb 26, 2016 | 05:58 PM
  #403
sixshooter's Avatar
sixshooter
My stock lines reached my 16's after rerouting.
Old Feb 28, 2016 | 07:40 PM
  #404
sixshooter's Avatar
sixshooter
Not sure if it's been discussed and I missed it, but found out today that Namz now makes complete 48" long hand control wiring harnesses, $60. So instead of having an extension plug into the factory wiring and having plugs buried in your bars, you just run the Namz harness from switches to under the fairing. I ordered a set today.
Old Feb 28, 2016 | 07:53 PM
  #405
orange52's Avatar
orange52
Installed LA Choppers 10" Twin Peaks bars today.
A Youtube video by RumblingRider and one on the Road6Customs site helped a LOT. Using compressed air to blow the pull string through the bars and using graphite instead of grease were great tips from Road6Customs.
Old Jul 20, 2016 | 09:14 AM
  #406
hauntedstuff's Avatar
hauntedstuff
Default Got a link on this,
Sounds like a smart way to go, don't know the part # do you, trying to find on the NAMZ site.
Thanks!
Old Jul 20, 2016 | 10:08 AM
  #407
HDRider15's Avatar
HDRider15
I have LA Choppers 12" Twin Peaks on my FLHX and have ridden over 400 miles in one day without any issues. They are very comfortable, 100% better than stock bars for my 6' height.
12" Twin Peaks all stock cables.
Old Jul 20, 2016 | 10:36 AM
  #408
Helomech74's Avatar
Helomech74
Thanks!
http://www.namzcustomcycleproducts.c...h_harness.html
Part number is: NHCX-CB14
Old Jul 20, 2016 | 11:41 AM
  #409
Trykon's Avatar
Trykon
10" Twin peaks...Comfortable. So used to them now, almost wished I went for 12"
Old Jul 21, 2016 | 02:54 AM
  #410
Gilesporter's Avatar
Gilesporter
Any advice to what apes would be good for my street glide, i am after something i can use with my stock cables and i don't have particularly long arms?
