Etms
Old Sep 11, 2014 | 09:30 PM
highwayman1224's Avatar
highwayman1224
I don't use it & I live in Phoenix. This is the coolest running Harley I've had ever since the 88" motors! I don't know if it's the rear cylinder heat shields or the water cooled heads, but this thing's a dream sitting at stoplights!
Old Sep 11, 2014 | 11:05 PM
RDGSG's Avatar
RDGSG
Originally Posted by spider14043
Why would anyone ever turn off the EITMS?
Because its annoying. I rode through 120 degree weather in late July from Needles, CA through Las Vegas, NV with stop and go in Vegas. Bike ran fine and I have lower fairings and the wind deflector fangs.
Old Sep 12, 2014 | 07:21 AM
nchogfan's Avatar
nchogfan
I turned mine off also. With the EITMS engaged it would stumble and sputter, almost stalling when I twisted the throttle to start rolling again. I definitely do not want to be sitting at a green light with a bike that has stalled.
Old Sep 12, 2014 | 07:38 AM
IUOE ROB's Avatar
IUOE ROB
Runs cooler them my '06 Twinkie, I too keep it off...
Old Sep 12, 2014 | 12:53 PM
Afdharley's Avatar
Afdharley
I keep mine off because I have no use for it. It is there to keep the RIDER cool, not the engine. I don't notice the heat so no need to turn it off.
Of course I came to this Limited after riding rigid choppers and sitting on a hot oil tank with my marbles resting on the rear cylinder of an S&S 113", so I really don't feel any heat now.
Old Sep 12, 2014 | 01:55 PM
batman.'s Avatar
batman.
And seriously, who the Hell cares if someone May be able to hear the difference in sound with one cylinder firing?
Cause I dont know ill ask... I was under the impression that it would come on on its own when necessary and then shut off when necessary. When I hit the button to see air temp oil and Emts it shows its disabled. Im riding a 14 sg.
Batman.
Old Sep 12, 2014 | 01:59 PM
Don81's Avatar
Don81
Batman.
When disabled it will never come on.
There are 3 status'. Disabled, Enabled, Active.
Active means you've got a 1 cylinder thumper banging away. Enabled means you're running on 2 but it's possible to run on 1 in the right cirumstances. Disabled means you will always run on 2.
Old Sep 12, 2014 | 02:02 PM
JustDave13's Avatar
JustDave13
That's why I blip the throttle before I take off.
Old Sep 12, 2014 | 03:01 PM
batman.'s Avatar
batman.
ok then how does one go about turning it to enabled? I read the manual but dont remember seeing how to change the settings..
thanks
batman
Old Sep 12, 2014 | 03:05 PM
Don81's Avatar
Don81
thanks
batman
While you're sitting still with the bike on, roll the throttle forward all the way and hold it there. If you're looking at that info screen you'll see it switch away from disabled.
You'll also see your cruise control indicator blink. If it's blinking green that means you enabled EITMS, if it's blinking orange that means you disabled EITMS.
