2015 street glide crossover pipe help
Old Apr 23, 2018 | 12:46 AM
Ryan42's Avatar
Ryan42
Default 2015 street glide crossover pipe help
So, My crossover pipe keeps sliding down about a 1/4in from the top of where its supposed to be. I inserted a new gasket and tightened the heck out of it. I have made sure every bolt is very tight but still slips down quarter inch after I ride. Is the pressure from the exhaust pushing it? I will mention that to put a new gasket in the pipe I had to bend the tabs out pretty far just so I could get the new gasket in without destroying it. Also it seemed the old gasket sat farther in the pipe than this one and this gasket sticks out a little because it was really hard to get it in all the way. Please any help would be nice
Old Apr 23, 2018 | 02:16 PM
Ryan42's Avatar
Ryan42
Bump since they moved it to this section!
Old Apr 23, 2018 | 03:03 PM
daveblank's Avatar
daveblank
2 questions
Do you have the support bracket that attaches to the bottom of the engine?
Is it leaking?
Old Apr 23, 2018 | 03:14 PM
Ryan42's Avatar
Ryan42
Originally Posted by daveblank
2 questions
Is it leaking?
yes support bracket is holding pipe up and is tightened down. Idk if it’s leaking I would have to spray some soapy water on it or something to see if it bubbles
but it still shouldn’t slide like that off. Damn thing
Old Apr 23, 2018 | 03:41 PM
GalvTexGuy's Avatar
GalvTexGuy
Just looking at your photos, it doesn't appear you have the female end slid far enough onto the male end up to that flange. Also, have you re-used the clamp? I know people have re-used them, but it is recommended a new clamp be installed or else they may not have enough clamping force to hold properly.
Old Apr 23, 2018 | 03:50 PM
Ryan42's Avatar
Ryan42
my issue is that the female end slides down the male end after I ride. So I pushed the female end all the way to where it’s supposed to be and tightened down. But after riding I noticed it slides down to where it is in the pics.
i have reused the metal clamps. I figured they last forever it’s just metal clamping down right how could it go bad??
Old Apr 23, 2018 | 04:13 PM
GalvTexGuy's Avatar
GalvTexGuy
If you look at a new clamp compared to a used clamp, you'll see how the old clamp has deformed from tightening. Once it's deformed, it doesn't have the same clamping force as a new one. At least, that's my understanding and I may be completely wrong, so take it for what it's worth. FYI, I have reused clamps, but the max is twice. When I install a new one, I use the lowest torque value specification and when I reuse them, I use the highest torque value specification. They're cheap, so I keep a couple on hand just in case.
Old Apr 23, 2018 | 04:36 PM
Ryan42's Avatar
Ryan42
ohhh okay. I just looked up the clamps they’re 20 dollars each which is ridiculous! Is there somehwre cheaper or maybe auto parts store has same thing?
Old Apr 23, 2018 | 04:51 PM
GalvTexGuy's Avatar
GalvTexGuy
I think I paid like $6 each for my clamps. Where are you looking?
Old Apr 23, 2018 | 05:00 PM
GalvTexGuy's Avatar
GalvTexGuy
For the time being, you could try making some aluminum shims from a soda or beer can.
