Everything 2018 FatBoy thread
Yeah I did do that - painted the scallops black.
I ran with them for a while but then decided to go down the Skull theme route and ended up with a set of the Willie G axle cap covers.
Fitted the DK Customs Intiminator Fork Valves, re-installed the PROGRESSIVE SUSPENSION Drop-in fork lowering kit (left the spacer height unchanged as I was sitting a bit low previously so this should give me @0.5" higher than before) and used Maxima Fork Fluid Racing Formula - SAE 10wt.
While the wheel was off, gave it a good clean/polish and fitted a Galfer Skull front disc using Colony chrome bolts.
With the Bridgestone tires I had, which the rear was a 240, I was running 40/42 front rear. Now with the Metzelers which I have a 260 rear I'm now running 36/36
This feels grippy but not underinflated.
I wonder why this feels like a better pressure than what I was running with a 240 tire.
A lot more sturdy now = Much better
I had to redo the forks as I realised that I had put the wrong amount of fluid in (I had measured incorrectly).
Anyway, got that all sorted out and back on the bike.
While I was there I fitted my skull LED headlight (with Kuryakyn harness adapter) albeit I haven't tested it yet.
This setup is even more comfortable than my Curved Fat Riser+OEM bars setup. Being able to underbar my mirrors is a nice touch. It gives me even more unobstructed view, and it helps with lane splitting. Plus it's nice to see more of the nacelle again.
This setup makes running a kicked back windshield WAY more aesthetically pleasing too. The bike looks so much better with a windshield with these bars on it than any other setup I've seen.
I need to get a matching upper Clutch Cable now. I will probably rebuild these bars later with an official HD handlebar on when winter comes in so I can install heated grips... again.
Back on the 240 rear that 40~42PSI was perfect. I got nice even wear across the rear tire without any cupping or weird wearing issues.
I could tell something was "wishywashy" when the 240 dropped to 36PSI or less. 36 feels pretty dam good on the 260.
I feel like the stiffer 260 sidewall and construction lets the PSI drop a bit and the tire gets more grip. Wear pattern will tell in the long run however.
The front for my bike I'm pretty sure it's also lower than others because it's also a rear ADV tire, so stronger sidewalls, and carcass.
> Managed to remove the plastic grommet (mentioned previously) by tapping it through the whole and out the back.
> Broke 3 different Torx tools trying to remove the Passenger footrest holder (unsuccessfully). Also couldn't remove the Passenger footrest holder from the exhaust bracket (new footrest holders on order).
> I fitted a different set (Chrome) V&H Staggered Shortshots.
(The PCX black shortshots were a right PITA to fit and in the end I didn't like either the fitment specifically of the bracket/hanger or the look).
> Previously fitted the Black Crankcase Cover but replaced the bolts with Alloy Boltz kit.
> I also replaced the bolts on the Primary Cover with the with Alloy Boltz kit.
> I fitted the Thunderbike swingarm covers.
> I fitted Chrome Radiator Grill.
> I cleaned and painted the Regulator and then fitted the Chrome Regulator Cover.
> Downloaded and installed an FP4 Tune.
Hi. What cover is it exactly? 74597-01 Isnt compatible with FLFBS or isnt it? Thx
PN 74597-01
I have one on my Fat Boy as well. Yes it does install on an FLFBS.
You can see it on my bike here.
