2018+ Softail Models Breakout
18+ Softail Oil Level - 114 engine
Old Apr 4, 2019 | 05:59 PM
kenny55's Avatar
kenny55
Default 18+ Softail Oil Level - 114 engine
All though on the low side, this seems to be the magic oil level (cold engine) to keep oil from spitting from the air cleaner. If I run it towards the middle of the dipstick I'll get oil splattered on the right side saddle bag and battery cover. I'll also have an oily grime on the bottom of the air cleaner cover. Did 100 mile ride yesterday and no oil anywhere.
Old Apr 6, 2019 | 04:45 AM
sandrooney's Avatar
sandrooney
Where is it when it's hot?
Old Apr 6, 2019 | 08:10 AM
martin10's Avatar
martin10
I have stopped checking my oil the way Harley recommends. People on this forum who are a lot smarter than me have said letting it idle on the side stand, like Harley recommends, leaves a lot of oil in the crankcase. I let it idle upright for a minute before shutting it off. Then check it as soon as I get off the bike. That will give you your highest oil reading on the dip stick. Letting it idle on the side stand and then checking it cold will show about 1/4 of the way less on the dip stick. I aim for the half way mark on the dip stick using the method I am using. I guessing yours will be close to that by letting it idle upright and checking it hot.
Old Apr 6, 2019 | 12:56 PM
Thingfish's Avatar
Thingfish
Mine sits right in the middle of the marks and no splatter. Guess each bike is a little different.
Old Apr 6, 2019 | 05:57 PM
kenny55's Avatar
kenny55
Oil level Hot engine. No splatter. Measured on jiffy stand
Old Apr 7, 2019 | 06:04 AM
sandrooney's Avatar
sandrooney
I am sure it will be fine running it there.
I do like martin10 and let mine idle upright before checking the oil, it does clear the sump better. It's always about halfway up the stick when cold and at the full mark or 1 dot down from full when hot. I have noticed that I can check the oil at the gas station and it will be as much as 4 or 5 dots down, I get back home and check it in the spot that I normally park it and it is at the full mark. The leval can be all over the place depending on where it's parked when you check it.
Old Jul 14, 2019 | 03:12 PM
Hulkss's Avatar
Hulkss
I can confirm this. I let the fully hot bike idle upright for a minute then shut down and fill to the full line on the side stand. If I then let it idle on the side stand and check the oil level, it will be four marks down. Idle upright again... back to full.
I'm going to stay with the idle upright method and fill to full before long rides. I can easily keep track of oil consumption and I won't over fill it.
Old Jul 14, 2019 | 03:39 PM
Another Old Timer's Avatar
Another Old Timer
Same here, After a ride, pull into Garage, turn off engine, place on Jiffy Stand, get off bike, remove gloves, remove helmet then jacket hang it up on Hanger, check oil and it is at or just below the picture above.. Keeping it at this level uses no oil no matter how hard I am running it. I find if I keep the oil level higher the bike uses oil.
Old Jul 15, 2019 | 05:40 AM
pittz5's Avatar
pittz5
I just picked up a 19 heritage and am having a hard time understanding the oil level in this bike. Several times now the oil hasn’t read on dipstick, Go ride for a bit and it’s half way up. What gives? I just did the 1000 mile service and put 4.5 qts in, warmed it up and stick was dry. This is nothing like the baggers I’ve owned. Haha
Old Jul 15, 2019 | 05:48 AM
Agoober's Avatar
Agoober
Yes idling it upright for 2 minutes after a ride does give the most consistent reading. However you check it just keep the process you use the same every time with a known quantity of oil in the bike.. Do not keep adding oil, this will cause the head breathers to puke it up. Running them in hard also helps with oil consumption , bikes run in slow eat oil ,bikes run in hard not stupid hard use none.
Peace .
