2018+ Softail Models Breakout
Tools for working on 18+ Softails
Old May 20, 2019 | 09:18 PM
AJ88V's Avatar
AJ88V
Originally Posted by Mchad
What in the world would make it bike specific? The oil filter is in pretty much the same spot on the M8 as the Twin Cam and Evo.
My disposable 1L bottle method works on every bike I’ve owned... I can’t see why that wouldn’t .
I can't say for sure, but I think I'll try Mchad's soda bottle method first and save myself $20.
Made a funnel out of aluminum foil for my wife's Sporty last year, but still made more mess than I wanted. Nice to have spray brake cleaner around to clean up.
Old May 20, 2019 | 09:46 PM
Mchad's Avatar
Mchad
The one “tool” I did buy from HD is their drain pan. It’s perfect for all three holes, covers the motor/trans/pri so you can drop all three at once, and it was pretty cheap as I recall. It’s also low profile so you don’t have to jack up the bike to fit it under.
Old May 20, 2019 | 09:47 PM
HuntWhenever's Avatar
HuntWhenever
A tool set to keep in the side case for road-side repairs or adjustments (alongside my Gerber multi-tool)...
Amazon Amazon
Old May 21, 2019 | 11:14 AM
AJ88V's Avatar
AJ88V
Default JIS screwdrivers
Here's a weird one to post for Harleys since it mostly applies to Jap bikes, but I do know these have come in handy a few times on my Dyna (like working on the instruments)
Amazon Amazon
JIS are the Japanese standard for cross-head screws. If you've ever wondered why your Phillips screwdrivers round out the heads of your screws, this is probably why the internal angles are different than the USA-based Phillips head. I haven't poked around the new Softail enough to identify screws with JIS, but these drivers are cheap and are useful for other Asian-made stuff (like your Hitachi leaf blower or something like that).
Old May 21, 2019 | 04:20 PM
HuntWhenever
https://www.amazon.com/Hozan-JIS-4-J.../dp/B00A7WAHTU
Hozan makes good stuff, too. Must of my electrical crimpers are made by Hozan.
Old May 22, 2019 | 01:05 PM
vynnski's Avatar
vynnski
Originally Posted by P51Driver
This Ernst funnel is not M8 specific and won't work on a M8. The M8 funnel Harley offers is M8 specfic.
The Ernst works just fine, here it is on my 2018 Slim.
Old May 22, 2019 | 03:27 PM
Mchad's Avatar
Mchad
https://www.amazon.com/Wadsworth-Rat.../dp/B0000WTWZ2
Thats a nice kit. They make quality stuff.
I put together my own, basically a high quality small adjustable wrench, a set of torx and allen bits and a mini ratchet for the bits. That, a handful of good quality wire ties, a 'lil larry LED light and thats all I ever needed for quick work.Clearly not changing a tire with it, but tightening a screw here and there, def.
Fits in a pocket in my molle handlebar bag.
Here's everything:
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
(the small one, just to give a little length to the bits)
Amazon Amazon
Also have one of these I got just for the holder. Put the better quality bits in it.
Old Aug 19, 2019 | 12:03 AM
HuntWhenever
Anyone know what size allen wrench is used for the front axle? (FLSB if it matters) I need to get me an allen socket.
Also, what size is the rear axle (left side)? I used a 1 1/8" socket, and it worked OK, but felt just a little bit sloppy. Maybe a 28mm?
Thanks
Old Aug 19, 2019 | 11:47 AM
Hlgsn1's Avatar
Hlgsn1
I can't get the Harley thing to work i just always take a thin cardboard like a cereal box cut it about 5 inches wide and as long as you need . Fold a crease lengthwise and slip it under the oil filfter. Keep it tight and never spill a drop.
Old Aug 19, 2019 | 12:19 PM
HuntWhenever
The answer was in a different thread, but I'll list it here also so its under the entire "2018+ Tools" category.
3/4" or 19mm hex socket / allen wrench.
