Out of topic question but howd you get that Bassani model to work with the bike? From the picture, it seems like you put some sort of bracket to lower the angle for the bottom of the brake pedal
Its a relevant question, to fit the system i had to:
1. Remove heatshields.
2. Remove/machine away material on the inside of the footpeg-mount (i dont know the correct english name for it) to get clearance for pipe.
3. I cut if the brakepedal where the push/pull-rod connects and made it 17mm longer downwards to clear pipe.
4. Shave som material off of rod-end (also for clearance issue)
This is the reason it looks like som brace, i didnt have time to make a smooth finish and paint it - i just wanted to ride.
And, before anyone says this is the reason for bad brakes, i had the problems before,and the main brake i have problems with is the front one 😊
My front brake is better now it's bedded in, the brakes certainly feel better than the brakes on the ST1300 I had, they were awful and no amount of bleeding or changing pads improved them.
The back on my lowrider isn't much use but I'll be putting forwards on in the future and that is supposed to improve the angle.
I have no problems riding spiritedly, two up, with the brakes I have but the rear could definitely be better.
At speed, rear brakes are less then 30% of your braking, and a much higher risk of a slide when used hard at speed, since all the weight shifts forward. All the pad changes and pedal raises won’t make much difference when you’re doing 70.
I improved my front brake with a simple pad change to Lyndall Gold + pads. My next step that I’ve been waiting anxiously for is an Arlen Ness big brake kit, which is a 15” rotor (more swept surface area) and a bracket to move the caliper out to fit it.
The Dyna guys have reported a substantial improvement. Arlen Ness just started producing their kit for the new Softails, and I grabbed one of them yesterday. As soon as it arrives next week I’ll post a review. It was about $350 shipped, so it will save me the +$2500 a new set of forks and wheel to support dual discs would cost.
At speed, rear brakes are less then 30% of your braking, and a much higher risk of a slide when used hard at speed, since all the weight shifts forward. All the pad changes and pedal raises wont make much difference when youre doing 70.
I improved my front brake with a simple pad change to Lyndall Gold + pads. My next step that Ive been waiting anxiously for is an Arlen Ness big brake kit, which is a 15 rotor (more swept surface area) and a bracket to move the caliper out to fit it.
The Dyna guys have reported a substantial improvement. Arlen Ness just started producing their kit for the new Softails, and I grabbed one of them yesterday. As soon as it arrives next week Ill post a review. It was about $350 shipped, so it will save me the +$2500 a new set of forks and wheel to support dual discs would cost.
Its nice thatone you information us that we are suppose to use our front brake mainly 😂😉
All jokes aside: please do review it, this could actually be a solution!
Yeah, I only said that because of the four or five posts on the rear brakes on a thread I thought was about braking in general. That and the OP stating his braking was much improved with work on his rear only.
And TBH, there are more ppl then you think who are afraid to use their fronts to their full potential and rely on rear braking for the majority of their stops...
As soon as the kit arrives and I figure out if I want to worry about the ABS sensor on my bike, or have a shop do the install, Ill post it.
Very glad to hear this! Love the Ness BBK on my Dyna SG. $350 is kind of spendy compared to what I spent on my Dyna kit, but probably worth it anyway.
Looking forward to your test report!
Yeah, I think they are actually $319 or something but since I got them direct, naturally they are the most expensive and have the highest shipping cost. But as you like to say, I dont care about the spend! ;-)
Not for something as important as brakes at least!!!
