2018+ Softail Models Breakout
Finding neutral difficult
Old Jun 12, 2019 | 01:19 PM
Sierra Nate's Avatar
Sierra Nate
How can he know what he's doing? Her hasn't even done the intro post yet! (is there a dead horse I can beat for a while)
voornas's Avatar
voornas
Thank you. After 30+ years of riding I've learned a thing or two.
Old Jun 12, 2019 | 01:20 PM
voornas's Avatar
voornas
You might want to check on that.
Old Jun 12, 2019 | 02:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Welcome to the forum
Old Jun 12, 2019 | 02:13 PM
felix27's Avatar
felix27
I had this problem after service adjusted the clutch due to another issue. They readjusted the clutch again and problem solved.
Old Jun 12, 2019 | 03:00 PM
uncle kebo's Avatar
uncle kebo
Ditto - My clutch went out at the same mileage and I got locked in 3rd gear. IMO Just a 1000 mile service needs to come early
Old Jun 12, 2019 | 03:05 PM
dceggert's Avatar
dceggert
Argh...okay back on subject....
Here is a tip to try to find neutral on a stubborn machine. Works from first up if you are already stopped, or 2nd down if you are coasting... It may even work from second down when stopped but I never tried that.
When stopped with the clutch pulled in and the transmission in first, apply light upward pressure to the shifter (not enough to actually move it) and then *slightly* blip the throttle. It should click right in. Too much pressure and it may jump to second so it needs to be very light pressure.
When coasting...two options:
1. As you are coasting with the clutch pulled in and in second gear, apply slight downward pressure on the shifter as you are close to stopping and it will click in when the engine speed and transmission speed get to be 'just so.' If this is not working well then....
2. As you are coasting with the clutch pulled in and in second gear, apply slight downward pressure on the shifter as you are coasting and blip the throttle when you are close to stopping and it should click right in. You have to be rolling pretty slow for this to work. Higher speeds (like maybe 5 MPH) will need a bit higher rev to the blip but will still work.
My old 1999 Ultra would not go into N for anything at a stop and this was my work around. Worked very repeatedly. My 2018 has moments too and this works for that. It also works on my BMW. I also teach MSF courses and when the students have issues finding N on the training bikes I tell them to try this and they pop right in. Give it a try and let us know if it worked....
Old Jun 12, 2019 | 03:47 PM
Jackie Paper's Avatar
Jackie Paper
Make sure linkage has free-play if not a hydraulic clutch. Some aftermarket shift rods with spherical bearings are too tight. When you pop it up out of first, if there is play in linkage, it will jump into neutral. The cam that the pin runs in is not designed to go from second to neutral.
Old Jun 12, 2019 | 04:57 PM
Uncle G.'s Avatar
Uncle G.
I put the heel shifter on my ‘19 Heritage. Finding neutral with my heel is a breeze.
Old Jun 12, 2019 | 06:10 PM
SPRINGER's Avatar
SPRINGER
Why must people ask this question every time someone mentions they choose to put the transmission into neutral at a stop light?
Maybe, just maybe... he knows what he is doing...
As I see it, I learn by asking questions. I simply asked him why he chose to put his bike into neutral when he stopped at a stop light, to find out why he chose to do so. If my interest in learning something from the OP bothers you in any way, than so be it, cause it's between the OP and myself,no one else.
