So,ive searched and googled but i couldnt find any info...
So i thought that maybe one of you could help.
I have a speedometer and tachometer left from my old bike (2013 streetglide)
Is there a way of using theese on my 2019 streetbob? (Im running fxrp fairing, so i would look nice with gauges there)
That digital gauge is canbus. I *think” the 2013 was canbus also. No way to know for sure, however it may be as easy as trying a Low Rider harness (two gauges) with the 2013 gauges, I expect you won’t hurt anything by trying.
The Low Rider gauge harness has a 4 pin connector on the bike side (canbus) and each gauge uses a 12pin connector. If your gauges are 12pin, maybe it’s worth a shot. The harness is about $35 US.
That digital gauge is canbus. I *think the 2013 was canbus also. No way to know for sure, however it may be as easy as trying a Low Rider harness (two gauges) with the 2013 gauges, I expect you wont hurt anything by trying.
The Low Rider gauge harness has a 4 pin connector on the bike side (canbus) and each gauge uses a 12pin connector. If your gauges are 12pin, maybe its worth a shot. The harness is about $35 US.
The gauge is a 12 pin, i will try to find the lowrider hsrness here in europe then and give it a try. Thank you!
