2018+ Softail Models Breakout
Rear shocks comparison
Old Aug 26, 2021 | 09:05 AM
Lammy1000's Avatar
Lammy1000
When running longer shocks do you set belt deflection to factory specs or run it loose? I installed a Fox 13.5" (2020 Sport Glide)and the deflection went from 0.6" to 1.3". Factory spec is 1/2 - 9/16".
Old Aug 26, 2021 | 10:05 AM
Hulkss's Avatar
Hulkss
You will need to be looser than stock depending on how much preload you have in the shock spring and the resting height of the bike suspension when you check the tension.
Old Aug 26, 2021 | 03:25 PM
Lammy1000's Avatar
Lammy1000
Thanks for the advice. Deflection is @ 20mm and seems fine.
Fox 13.5" shock is amazing. From bump absorption to cornering this shock is a significant improvement from oem.
Old Aug 26, 2021 | 08:32 PM
Agoober's Avatar
Agoober
I never even bothered to look at it , I just rode it.
Rustyg500
Sep 6, 2018 03:05 PM
Dazzauk
EVO
Jul 9, 2016 11:16 AM
DottoreItalia
Aug 8, 2013 01:54 PM
flhtcijohn
May 23, 2011 02:56 PM
screamn_eagle
Apr 23, 2008 05:40 PM
