2018+ Softail Models Breakout
Foot Control Bracket!!
Old Aug 4, 2019 | 11:38 PM
Scott Shepherd's Avatar
Scott Shepherd
Stage IV
Default Foot Control Bracket!!
Has anyone else had a problem getting the two torx bolts out? I’m afraid I have stripped them a tiny bit. None the less stripped is stripped and I need some help getting them out! These suckers are in there tight. I’m kind of frustrated with the type of bolt used for this application. If your going lock tight something like that do it to a bolt that can’t be stripped so easily!! Anybody have any suggestions? Thanks for any help you can provide.
Old Aug 5, 2019 | 01:48 PM
Uncle G.'s Avatar
Uncle G.
I'm finding that H-D has used Loctite on every fastener on my 2019 Heritage. Totally unnecessary IMO, but I suppose it's cheaper than nylok nuts or or lock washers. In my experience, button head Torx screws and Loctite is a recipe for disaster.
Old Aug 7, 2019 | 11:32 AM
Crocodile Tears's Avatar
Crocodile Tears
yeah, my lowrider had them loctited in like I've never seen before. Its a miracle the stuff wasn't bleeding out everywhere around. I ended up having to run the new bolt in and out about four times to clean the threads decently and then reapply a sane amount.
Old Aug 7, 2019 | 11:40 AM
AJ88V's Avatar
AJ88V
If you suspect a bolt has Loctite on it you can either heat it or wick acetone on it to soften up the plastic for easier bolt removal.
Old Aug 11, 2019 | 04:13 PM
Uncle G.'s Avatar
Uncle G.
Problem with that is that heat or acetone will damage the surrounding painted surfaces.
Old Aug 11, 2019 | 07:09 PM
Hulkss's Avatar
Hulkss
You need a set of thread chasers (not taps) to clean threads that have dried loctite.
Old Aug 12, 2019 | 02:05 PM
sumncguy's Avatar
sumncguy
Mine on the now traded Softail were ridiculously tight. Trying to remove them from factory install to add board extenders.
I took a 3/8" rachet with an extension and put a pipe on the end of the rachet for leverage .. got them out that way then cleaned them up.
I reinstalled with locktite, but I just used the locktite at the top of the bolt only.
Rusty Axle
Shovelhead
Jun 28, 2017 09:39 PM
bobbyjoes
Jun 23, 2014 09:44 PM
Scorpio49
Sep 26, 2013 09:00 PM
Rainmakr
Jan 1, 2013 09:31 AM
Tin Man 1
Oct 20, 2007 06:05 PM
