Help removing bolt - BOLT HAS BEEN REMOVED
Old Oct 17, 2007 | 09:29 PM
Tin Man 1's Avatar
Tin Man 1
Default Help removing bolt - BOLT HAS BEEN REMOVED
I am trying to remove the passenger footboard mounting bracket. I was able to remove one side, but the other side won'tcome loose. The bolt requires an allen wrench and shoulders inside are starting to round. Any ideas on how I can get this bolt out would be greatly appreciated.
Old Oct 17, 2007 | 09:38 PM
soos's Avatar
soos
Default RE: Help removing bolt
I would try cutting the bend off an allen wrench and inserting the long end into an impact driver. If you don't have an impact driver, rap the long end with a hammer and try rotating the wrench after a few hits. Keep the allen wrench straight in the cap screw.
Sann_X's Avatar
Sann_X
Vise Grips..
Old Oct 17, 2007 | 09:45 PM
mhud's Avatar
mhud
I got a set of allen wrench sockets from Sears. Helps get a lot more torque when needed onb these hard to get to HD bolts.
Old Oct 17, 2007 | 09:50 PM
TexasRedneck's Avatar
TexasRedneck
As suggested, an impact driver with a socket-type allen wrench. If that fails, weld a nut to it an' pull it off, then replace the allen head bolt (which should be done now anyways, since it's startin' ta round out).
Old Oct 17, 2007 | 10:33 PM
gregm's Avatar
gregm
You might try using heat along withan impact driver, somethread- lockingproducts needaround 400 degrees to get them to release.
Gregm
Old Oct 18, 2007 | 05:57 AM
Tin Man 1's Avatar
Tin Man 1
I appreciate everyones suggestions. I don't have an impact wrench or torch to heat it. I have a variety of allen wrenches that are very good quality. The bolt doesn't have loctite on it. And I have put penetrating oil on it. It just won't budge. Doesn't help that it is starting to round off. Any ideas what a dealership, Dallas area, would charge to remove a passenger footboard mounting bracket bolt?
Old Oct 18, 2007 | 06:12 AM
piggy's Avatar
piggy
RICK why go to a HARLEY Stealer, any good service station mech, can do the job for you, without ripping you off, just my 2 cents,
rocknrod's Avatar
rocknrod
If it's an allen head screw, Cap Head. Not a Button Head. And its notcountersunk into the footpeg bracket, I would use the largest Vice Grip I could get on it, as tight as I could make it, ie two hand squeeze. Then use some assistance (pipe) to turn it (Make sure the Vice Grip face the correct way)
Also, and I know this seems stupid, but are you turning it the correct way? "Righty Tighty Lefty Loosy"
Then go buy a new fastener to replace it.
If its counter-sunk into the foot-peg or a button head, and you round it out? Your looking at a drill and tap jobor welding a nut on it.
Since you dont have that ability at your home, figure $35 to $45 an hour to get-er done. If your lucky.
Dont you just hate it when that happens?
Old Oct 18, 2007 | 06:25 AM
RDM's Avatar
RDM
You could try tightening it and then try to loosen it. I've had bolts that seemed really stuck come loose that way.
