2018+ Softail Models Breakout
Breakout 2018 model Side stand
Old Aug 17, 2019 | 06:09 AM
Patrick Valli's Avatar
Patrick Valli
Stage III
Default Breakout 2018 model Side stand?
Hi does anyone know how or were I can get a side stand that is shorter than the original one on my breakout 2018 model as I have lowered it and it almost feels like it is sitting upright when it is dropped.
Old Aug 17, 2019 | 06:12 PM
HeelDragger's Avatar
HeelDragger
I had the Profile Low Front Suspension installed on my 18 Deluxe.
As per the HD install instructions they required the installation of the shorter Jiffystand...
’18-later FLDE, FLHC, FLHCS, FLSL, FXBB, and FXLR models. FLDE model requires separate purchase of Jiffystand P/N 50000156. FXBB models require separate purchase of Jiffy Stand P/N 50000127
Hope this helps
Old Aug 17, 2019 | 09:32 PM
Patrick Valli
Stage III
Thank you for the information do you know if the jiffystand is a bolt on bolt of replacement or do I have to make modes for the fxbr
Hope this helps
Old Aug 18, 2019 | 09:35 AM
HeelDragger
The 2018 Softail Parts Manual shows item # 32 part # 50000137...Bracket, jiffy stand is common to all models. Going by that, it appears that there is no modification necessary. Please note that the replacement stand for my bike as mentioned in my first reply is part # 50000127 which according to the parts manual is the stock jiffy stand. At this point, I'm not so sure if it is a shorter stand. You probably need to talk to a HD parts guy for better info. For what it is worth, my lowered bike has a normal lean when on the stand. It does not sit upright at all.
Old Aug 18, 2019 | 09:44 AM
Blackp5ca's Avatar
Blackp5ca
What suspension did you lower your Breakout with Patrick?
Old Aug 18, 2019 | 04:17 PM
Patrick Valli
Stage III
Once again thank you for the information and your time I will check with my local HD
handirifle
Apr 30, 2019 12:32 PM
little squirt
Nov 12, 2014 02:26 PM
clap
Sep 22, 2014 06:52 PM
ryderbiker
Sep 21, 2012 09:22 PM
7125
Jul 25, 2009 11:11 PM
