touring
3,000 RPM (80 mph) does seem to be a harmonic hot spot, but cruising below 78 or above 82 solves it. My hands don’t go numb, but that can be bar position too for those who suffer.
I’ll still say there are “smoother” models. Touring and TC Dyna’s.
3,000 RPM (80 mph) does seem to be a harmonic hot spot, but cruising below 78 or above 82 solves it. My hands dont go numb, but that can be bar position too for those who suffer.
Ill still say there are smoother models. Touring and TC Dynas.
Solid mounting allows for the classic frame lines of the Softail (mimicking the old rigid mounts). Rubber mounting (Dyna and Touring) requires a boxier frame to allow motor movement at the mounts.
The vibes on my Heritage dont bother me, but switching to my wifes Road King Special on our last trip it was remarkably smoother...so is my 09 Dyna at freeway speeds.
The Softail line has always been partly about the classic HD look. They engineered 100% of the vibes out and test riders complained it didnt feel like a Harley, so they dialed a bit back in....cant make everyone happy I guess.
David Gilmour
Its like my ex wife used to say, they could hang you with a new rope and some of you would bitch about it.
You can solid mount a Harley engine, but it really needs counter balancers to do it, just like HD did with the new Softails. The Sportster used a solid mounted, non-counter-balanced engine for years until 2004. I'll tell you, the old Sportys just come "alive"as the revs climb - it's part of their charm - but it's also very fatiguing to ride for more than an hour. Above 4-5000 rpm, the gauges become hard to read, everything in the mirrors turns into little circles, and small parts stress crack with time.
The counter-balancers in the Softails seem to do a great job hitting the sweet spot of "good" Harley vibration and not introducing too much high-frequency vibe. The balancers add some mass to the engine, but you lose weight in the motor mounts and probably the frame too, plus you get an overall tighter chassis, which is why these things handle so much better.
