2018+ Softail Models Breakout
Softail inverted fork diameter
Old Aug 26, 2019 | 06:50 AM
Mchad's Avatar
Mchad
Default Softail inverted fork diameter
I’m wondering if anyone knows the diameter of the upper tubes (where the triple tree clamps) of the new inverted forks.
Old Aug 26, 2019 | 09:02 AM
norton74's Avatar
norton74
My Sport Glide inverted fork tube OD measures 59 mm just below the lower triple tree clamp
Old Aug 26, 2019 | 09:18 AM
Mchad's Avatar
Mchad
Perfect, thank you!
Old Aug 26, 2019 | 09:43 AM
modular's Avatar
modular
Is someone going to have their trees machined to accept the USD fork legs?
Old Aug 26, 2019 | 10:35 AM
Mchad's Avatar
Mchad
I don't know, I was tossing the idea around...
Old Aug 26, 2019 | 04:58 PM
Hdbkstl's Avatar
Hdbkstl
You thinking about harley takeoffs or complete new set of usd forks.
Old Aug 26, 2019 | 05:19 PM
Mchad's Avatar
Mchad
Dont know. Takeoffs originally. Though as I think about it, Howard Messner makes a set that has his custom trees and Öhlins inverted forks. It’s a fair bit more $ then some HD takeoffs, but are a whole different league. Probably more mom then I want to spend. Take offs would definitely be the most economical. They would also allow for the possibility of dual disks, but I’m not sure how a the ABS system would like adding a second caliper.
Old Aug 26, 2019 | 06:34 PM
HuntWhenever's Avatar
HuntWhenever
... but I’m not sure how a the ABS system would like adding a second caliper.
Go crazy...grab an ABS module from a Fat Bob
Old Aug 27, 2019 | 01:09 AM
Jbco2's Avatar
Jbco2
What is the length of that fork from the axle?
Thanks
Old Aug 27, 2019 | 07:24 AM
Hdbkstl's Avatar
Hdbkstl
I asked a friend about that. He said it needs some sort of pressure regulator.
