2018+ Softail Models Breakout
So what should i do for my M8
Old Sep 12, 2019 | 02:58 PM
LOW&GO72's Avatar
LOW&GO72
Default So what should i do for my M8
Here the situation guys, i bought a FXFB 107 back when they came out in October of 2017 I only put 254 miles up until today. So thats almost 2 years with the same engine oils... So do i finish my break in these oil or flush them all out & what do i replace them all with break in oil for the engine or run full synthetic now...?
Old Sep 12, 2019 | 03:14 PM
TriGeezer's Avatar
TriGeezer
Harley doesn’t use break in specific oil. I’d change it now to whatever you want use use that is recommended. Then make sure you change it every 5,000 miles or 1 year whichever+comes first.
Old Sep 12, 2019 | 04:36 PM
LOW&GO72's Avatar
LOW&GO72
Should i change any other oils..?
Old Sep 12, 2019 | 06:17 PM
sandrooney's Avatar
sandrooney
Change them all.
Old Sep 13, 2019 | 01:38 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by sandrooney
Change them all.
And ride the bike more.
Old Sep 13, 2019 | 05:51 PM
Las Vegas Jim's Avatar
Las Vegas Jim
Three recommendations.
1. I would be more worried about the gas in the tank, depending on how long since fresh gasoline was put in the tank. If the gas is more than 6 months old, I would consider draining the tank and replacing it with 1-gallon from the gas station you bring home in a container.
2. The oils aren't going to go bad in just two years. I recommend riding it more and getting 1k miles on the bike as soon as possible. You can then take it in for the 1k miles service. This is the most important service on any new bike. You certainly want to have it performed before your warranty expires.
3. At the 1k service, make sure full synthetic fluids are put in all three holes.
FYI: I just had the 1k service performed on my 2019 Low Rider. I was surprised at how much smoother the throttle and clutch operated and the improved smoothness when shifting the transmission.
Old Sep 13, 2019 | 06:08 PM
2018 lowrider M8's Avatar
2018 lowrider M8
Thumbs up
Wise Words well said
Old Sep 13, 2019 | 07:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Why bother? It`s not like you are going to wear the bike out...
Old Sep 13, 2019 | 08:53 PM
LOW&GO72's Avatar
LOW&GO72
All great points the simple answer is just ride the thing i guess. But the gas is always been alittle but fresh.
Falcon195
Jul 17, 2013 02:12 PM
Jim Kraft
Oil Archive (no new posts)
Feb 18, 2013 10:17 AM
Bo Joe
Jul 29, 2012 05:42 PM
cHarley
Dec 8, 2011 01:01 PM
Bluegrasser
14
May 3, 2009 09:14 PM
