I can't find the thread, but a member posted a link to HD's application to the FCC explaining how the system works.
Every few seconds an armed bike emits a RF signal. If an assigned fob is within range, the fob wakes up, and emits a RF signal to disarm the bike. This back and forth RF communication continues every few seconds while the fob is within range. If the fob is out of range, and never awakened by the bike's RF signal, the fob's battery is not being used. I would presume the battery in a dormant, out of range fob would outlast the battery in a fob that is emitting a RF signal every few seconds.
And the answer to your question how do you know when the battery is going dead. WHEN YOUR BIKE WONT START
You don't need to wait that long. I knew my battery was getting low because the LCD display actually said "FOB BATTERY LOW" when I flipped the power switch on.
Question for you. Does this note appear in your 2018 Owner's Manual?
I see it in the 2019 Owner's Manual, but I can't find it in the 2018 manual, unless I missed it.
Don't think it showed that on my 2015 maybe on my 2019 it will show and when it does I will have a new battery with me to install
Yeah, I don't know about for earlier models, but it's definitely a feature on the 2018+ models.
As for the question about whether proximity drains the battery faster, I haven't done any empirical testing but I can't see how it wouldn't. I have two fobs, the one I ride with and the other I just keep stashed somewhere safe. Since the one I ride with gave the low battery warning, I thought I'd check the other one to see if it did also. It didn't. Now, that's a sample size of 1, so it doesn't mean much, but it does make sense.
Battery is a CR2032. Amazon is a good place to get them. A 4-pack is currently $3.88 and 20 pack of Panasonics is only $6.67. I have several key fobs that use this size, so I just buy a bunch and store them in the fridge.
Originally Posted by touchdown
I always carry a extra battery just in case.
Great idea, touchdown. Think I'll throw one in my handlebar pouch.
Now might be a really good time to set your PIN to over-ride the lack of a working key fob. Instructions for setting the pin begin on page 51 of my 2019 Owner's Manual. Ideas for 5-digit pin number might be yours or your wife/kid/mom's birthday or a zip code. IIRC, you can't use zeros. Also a good idea to practice using the PIN and maybe store the instruction card in your wallet or on the bike somewhere. If you're stuck with crappy winter weather like we've had the last few weeks in Virginia, this will at least give you an excuse to play with your bike in the garage.
