2018+ Softail Models Breakout
SE adjustable push rods
Old Dec 27, 2019 | 07:58 AM
Koch's Avatar
Koch
Default SE adjustable push rods
Can anyone let me know what is the TPI of the adjustable push rods in a SE stage two torque kit. Is it 32 or 24? Nothing is mentioned in the Installation sheet. I am riding a 2018 Fat Bob FXFB. Thanks.
Old Dec 27, 2019 | 08:17 AM
golfblues's Avatar
golfblues
24 when I put them in my 09
Old Dec 27, 2019 | 08:22 AM
r0de_runr's Avatar
r0de_runr
My instruction sheet said adjust to 2.5 turns, so I adjusted to 3 turns.
Old Dec 27, 2019 | 12:48 PM
24v's Avatar
24v
If you have the pushrods, count the threads?
Old Dec 28, 2019 | 12:24 AM
Koch's Avatar
Koch
Thanks all. The reason I asked is after installing the Stage two torque kit I started getting a ticking sound after a minute of initial start up. It would persist for another three minutes and go away. The dealership has adjusted the push rods twice and now they are suspecting a problem with the stock lifters wherein the oil is bleeding away and only later being pumped up. They have ordered SE lifters part no 18572-13 hence I asked for the TPI. With the stock lifters and with 2.5 turns the noise was bad. Now after 4 turns the sound appears as mentioned in initial start up and vanishes. I am waiting for the new SE lifters and hopefully get rid of the sound. I have this feeling that I made a mistake with the stage two. The bike was running beautifully with stage one. The bike is in warranty and here there is no way I can get after market parts. I have to stick to MOCO.
Old Dec 28, 2019 | 05:21 AM
Agoober's Avatar
Agoober
Stay with it they'll get it and it will be better. You are in Southern India yes ?
Namaste .
Old Dec 28, 2019 | 05:22 AM
OldMike's Avatar
OldMike
As stated before your dealer can easily count the number of threads.
Did they use NEW stock lifters or re-use your old lifters?
Old Dec 28, 2019 | 08:45 AM
Koch's Avatar
Koch
Agoober - Namaste and Pranaam to you too. That’s correct I am in deep Southern India whereas you should be freezing and here its hot.
OldMike - They used the old lifters and not new. I will have them count the number of threads when I take her in to replace the lifters. Is it OK if replace the stock ones with the SE lifters Part number mentioned earlier. They have ordered the same. The dealership has also sent a note to HD Singapore requesting advice.
Old Dec 28, 2019 | 08:54 AM
OldMike's Avatar
OldMike
I can't comment on the SE lifter part number. But, it's standard procedure for new cam to use new lifters, make sure to check the cam lobes for damage.
Old Dec 28, 2019 | 03:07 PM
justintyme73's Avatar
justintyme73
Not with Roller cams, If you were talking flat tappets yes.
