2018+ Softail Models Breakout
Idle Issue.
Old Feb 3, 2020 | 02:30 PM
felix27's Avatar
felix27
Forgot to add. The higher idle is triggered by the clutch switch. So when your in the friction zone pressing the clutch in n out is what triggers it mostly.
Old Feb 3, 2020 | 02:47 PM
sandrooney's Avatar
sandrooney
Originally Posted by Hulkss
From the service manual:
with the engine warmed up
1. Start engine.
2. Increase rpm to 2500 rpm and bring engine back to idle.
now take your hand off the throttle grip
3. Turn IGN OFF.
4. Repeat previous steps a total of four times.
This process will help the controller learn throttle plate position.
Note: Anytime you shut your bike off and the throttle is not in its normal closed position you may cause the computer to screw up the idle speed.
Hulkss,
Where did you find this in the manual? Thanks
Old Feb 3, 2020 | 02:48 PM
sandrooney's Avatar
sandrooney
Thanks felix
Old Feb 3, 2020 | 07:34 PM
Hulkss's Avatar
Hulkss
Originally Posted by sandrooney
Hulkss,
It's in the Electrical Diagnostic Manual part number 94000555.
Old Feb 4, 2020 | 04:53 AM
sandrooney's Avatar
sandrooney
Thanks a lot
Old Mar 7, 2020 | 04:22 AM
sandrooney's Avatar
sandrooney
I had Fuel Moto do a revision on the tune and it pretty much fixed my idle issue. Thanks for the help.
Old Mar 15, 2020 | 01:58 PM
jimsreddyna's Avatar
jimsreddyna
Hulkss is correct. I had the same problem on my 2009 E Glide. Hitting the Kill Switch before the bike is all the way down to idle will tell the computer to raise the idle speed.
Nov 5, 2017 09:41 PM
nkfd13
Apr 1, 2011 12:41 PM
2000FiveOh
Jul 14, 2009 01:35 PM
Willy G.
Apr 8, 2009 07:02 AM
Stumpman
Mar 24, 2006 10:08 PM
