FXDR handlebars?
Anybody have a solution to bring the bars up and back maybe an inch?
Can't believe somebody that does metal casting doesn't make a simple bolt on extender to take the clip on tubes and move them up and back an inch.
The bike would have such better ergos. It would take a few minutes to install and keep the low clean look of the clip ons.
Amazed somebody has not done this. I'd easily pay $150 for two pieces of matte black aluminum threaded for the stock handlebar tubes.
Why Harley does not make this product, I'm dumbfounded.
Or just make a set of reach clip ons that come back and up and extra I'm or so.
Aftermarket Harley drag bars are too high IMO and ruinnthe low profile look.
Rizoma makes risers and a drag bar but studying pics makes me think they may be even further forward than the Harley hand position.
Anybody?
I just posted in the "what did you do"?
I WAS going to make some quick "extensions" like you describe. Actually started milling/drilling on my last day off.
To make them not look TOO cobbled, I would have recessed where they bolt on, (top and bottom) so they didn't add the 3/4" width.
My 1 1/8" end mill is really dull and just melts the AL.
Also, the right side hase to have room for the brake hose.
I tried to "reverse" them and it would have worked for a little more pullback.
So, to make some "quick" extensions. The right side would have to have an angle in the part. (unless you could change the Banjo bolt"?
Just find some T-bars, or other bar/riser combo you like!
JM
Was going to get some thicker material and do some fancy stuff but I just want to get it done. Will just shoot it black.
Then I can always make another one if needed. The new fairing will cover most of it.
JM
Have an offset on the bottom where it threads in to clip on and sink the bolt hole on the top like Harley did on the original bolt holes.
Hard enough to get the right one the first time for this model.
Arlen Ness 08-029 off Amazon. paid 22 bucks, and came in one day. They fit!
Some 5-6" Fatbob risers/bars. Have just a little offset. The 1.5" bars look slick to me.
And tilted back that 10 degrees??? The Deuce risers are 6" with a 2.5" pull back and felt really good with the Drag bar.
Even better with the Buell (flat track style?) bar.
Don't like the look of curved risers AND bars with rise. Drag bars? Cool.
JM
JM
JM
Can't believe Harley does not make a nice black pull back riser that isn't sky scraper tall. Their offset risers of shorter variety only available in chrome.
