2018+ Softail Models Breakout
Street bob suspension setting.
Old May 10, 2020 | 08:38 PM
Super2k's Avatar
Super2k
Default Street bob suspension setting.
Hey guys am I reading this chart right or not? I way probably closed 190 to 195. It’s telling me the suspension setting preload should be zero. 2020 street Bob I’ve been running at three and I thought god this thing is hard compared to my old 2004 street glide. Supposedly the shop set it up that way and said the three would probably be the right setting. Problem is it doesn’t have a zero it goes from 1 to 7. So I’m thinking maybe I should try it out at one. What are your guys his suspension set ups And bikes particularly the street Bob or something close to that.?
Old May 10, 2020 | 08:59 PM
OldMike's Avatar
OldMike
Owners manual for 2020 Softail page 52 looks like you could go #1 or #2. There is no zero listed in my book.
Old May 10, 2020 | 09:03 PM
Super2k's Avatar
Super2k
Omg I was looking at the fat Bob, it’s been a long day. Went out and clean the bike and it’s starting to drive me a little crazy. There’s so many different textures on that bike the black the aluminum the chrome I don’t even know where to begin half the time. And then trying to get all the water off it. But thanks so much for the reply.
Old May 10, 2020 | 09:05 PM
Super2k's Avatar
Super2k
Would you error on stiffer or softer, I like to ride it hard and hard into the corners. Well as much as my skill will dictate anyway.
Old May 10, 2020 | 09:06 PM
OldMike's Avatar
OldMike
I set mine to the lighter side and have not bottomed out. The bike will let you know.
Old May 10, 2020 | 10:04 PM
Steve Sportster's Avatar
Steve Sportster
I run my FLHCS at "2". I've added a bit of weight with options (TourPak, JES fangs), but I only weigh 160 without boots, leathers, etc. Rides fine and I don't have to mess with it when I load up for a road trip, either.
Old May 10, 2020 | 10:45 PM
Superdog3:16's Avatar
Superdog3:16
I got a Breakout, I'm 200ish, I run at 1.5 or so. Seems good for me.
Old May 11, 2020 | 12:06 AM
Agoober's Avatar
Agoober
FXBB and I'm 240ish , I run more oil in the front and am at 4 when the manual says 3 for me, this keeps the bike higher in the stroke for more ground clearance mid corner.
It does blow straight through the stroke on a square edged/pot hole but it was doing that anyway. Also running 34/35 in the front tire.
Old May 11, 2020 | 03:00 AM
Mart's Avatar
Mart
It's preload. The spring doesn't look to be progressive, so it only changes ride height, not ride quality, unless you have been bottoming out. New shock needed to improve ride quality, esp. one that has dampening adjustment.
Old May 11, 2020 | 05:19 AM
Super2k's Avatar
Super2k
interesting. There’s a guy that has a blog and didn’t realize he was on a higher number. He changed it and said the ride difference was drastically different.
