2018+ Softail Models Breakout
Baffle removal of screening eagle
Old Jun 14, 2020 | 11:31 AM
Nalgz's Avatar
Nalgz
Stage IV
Default Baffle removal of screening eagle
I have a 2020 streetbob. If i remove the baffle from the screaming eagle slipons. Would i need a tune?
Old Jun 14, 2020 | 12:04 PM
nevil's Avatar
nevil
You should get it tuned, but you didn't say if it was tuned before and if you changed the intake as well. Either way, running without the baffle will probably void your warranty.
Old Jun 15, 2020 | 12:50 PM
fdh161's Avatar
fdh161
Short answer is a definite yes. Any major change in air flow (in or out) requires a remap. If you had the SEST as part of your Stage 1 package, you can do it yourself with a PC based laptop, the SEST software (free from HD), and a set of cables ($25 from Harley). The software is designed so you can use either a dyno or "closed course" road driving to provide the inputs needed for the tuner to make the changes. It's really pretty easy to do.
Tankoma
Exhaust System Topics
Oct 1, 2014 08:51 AM
lloydy
Screamin Eagle CVO Models
Apr 24, 2013 08:21 AM
towboattrash34
11
May 11, 2008 05:16 AM
mfisher1@bak.rr.com
Nov 5, 2006 01:22 PM
bodyman0
Jan 18, 2006 07:52 PM
