2018+ Softail Models Breakout
Traffic Lights
Old Jun 19, 2020 | 06:31 PM
nj08SEUltra's Avatar
nj08SEUltra
Thanks. Not sure I have the wherewithal to hold up the bike at 45 degrees, but I'll give tilting it a little less a try.
Old Jun 19, 2020 | 07:20 PM
rjg883c's Avatar
rjg883c
Originally Posted by nj08SEUltra
I now have 700+ miles on my '20 Heritage 114 and am loving it. I'm wondering if anybody else has noticed that their Softail does not seem to register on the road sensors that switch red lights to green. If I'm the only vehicle at certain intersections, the light will stay red. My prior Harleys were all Touring models with more metal and heft, and I never noticed a problem.
I don't know where you are but I have good luck after putting my scooter over one of the vertical, as opposed to horizontal, cuts in the pavement over the sensor. It is more difficult, after a street is repaved, to see a cut but the general location doesn't change. So I get into the habit of riding over the portion of a lane that should trigger the light to change.
And now the sensors here are in a circular, rather then rectangular, shape, adding difficulty.
Running a red, after stopping, works. But there are times, due to traffic, it isn't that easy.
Old Jun 19, 2020 | 10:50 PM
HuntWhenever's Avatar
HuntWhenever
As others have mentioned...try to stop on the outer perimeter of the box or circle...you want to be on the cut or "line". Some of the loops (the rectangular cut) have a double-line up front (toward the intersection). This double-line is an extra loop to make the sensor more sensitive for motorcycles. Stop with your frame above that double-line.
My best friend is a traffic signal technician, so he clues me in on best practices.
Old Jun 19, 2020 | 10:53 PM
HuntWhenever
I've ran across the circular type when I venture into Indiana. I seem to have pretty consistent performance when stopping along a chord of the circle (front wheel on the perimeter, back wheel on the perimeter).
Old Jun 20, 2020 | 12:54 AM
Herbkell's Avatar
Herbkell
I found out the hard way that in British Columbia it’s not legal to do the “wait one cycle and proceed with caution” thing.
its bloody stupid, since my ticket I waited a long time trying to turn left at a traffic light intersection before finally giving up and going straight on.
Old Jun 20, 2020 | 11:41 AM
DikTish's Avatar
DikTish
Here in the state of Wisconsin My son recently completed his safety courses for a riding license. He informed me that the state has a provision of wait a cycle and proceed with caution. I was not aware of that.
Old Jun 20, 2020 | 12:32 PM
barneyboy's Avatar
barneyboy
Actually, it's wait a minimum of 45 seconds, then procede with caution, been that way since 2006. Most signal lights are no longer controlled by timers, instead "cycles" are dictated by traffic flow. In certain situations, a "cycle" could be hours.
Old Jun 21, 2020 | 04:08 AM
Q-Ball82's Avatar
Q-Ball82
Would like to know the legality of this in the UK,I commute to work very early and often have to go through a red light due to it not knowing I'm waiting. I have waited nearly 5 mins in the past before carefully going through on Red!
Old Jun 21, 2020 | 09:19 AM
iHodor's Avatar
iHodor
Originally Posted by AJ88V
As others mentioned, some states have passed laws - and I actually carry a copy of the one for Virginia, since the police may not be aware and may not cut you slack
https://law.lis.virginia.gov/vacode/...0intersection.
As
Some people sell big magnets that you strap to the bottom of your bike. I've never had one, don't know if they work.
Found this article while looking for the magnets: https://www.revzilla.com/common-trea...re-motorcycles
On my VTX 1800 I kept a "stick" of about 24 1/8"x1/16" magnets stuck to the bottom of my right floorboard. Before that I'd have trouble with a couple of lights in particular. Afterwards I never had any issues. Worked for me
Old Jun 21, 2020 | 12:36 PM
vycor's Avatar
vycor
I did the same on my Slim. Put four strong magnets on the bottom and no problems. There was this one light on base that would always give me troubles no matter how I lined up over the sensors, after I threw the magnets on, no more problems.
