Hi, when moving my fatbob (2019) around in the garage last night (with engine off), I heard this scraping sound from the front disc brake. I put my camera next to it and then rolled the bike again -
I'm assuming this is not normal. Is this something that I can try to fix on my own? Or is it off to the dealership? (I'm not very mechanically inclined).
I don't know how long this has been the case - I usually have the engine on, so wouldn't hear this normally.
Check to see if you have a rock lodged anywhere around the pads. That can happen too. Though as Mike said it sounds normal.
If you have a jack lift the bike and listen to both brakes one at a time. All hydraulic brakes have a little drag afaik. They are designed that way and while you can't always hear them it is there.
Indeed, and I would add, a recording can increase or lower the actual volume of the rubbing so it's not easy to judge from my couch. My bike when rolled doesn't sound as loud but If I record it, I can probably make it louder.
Thank you. I checked for any rock/debris, but couldn't see any (possible it is there though - hard for me to see it without taking the pads off)
I don't have a lift unfortunately.
This is pretty readily audible in an enclosed garage. (I tried recording the sound on the rear wheel. It is there, but much quieter than the front).
, which seems to indicate that this is normal (like Mike said) - that's the same sound I hear on mine.
Just wanted to make sure that I wasn't ruining my brakes.
What year is the bike and how many miles on it? More accurately, how many miles are on the pads? See if you can get a photo of the out board brake pad where it touches the disc.
As said, it isn't uncommon for the pads to very lightly contact the disk even when no hydraulic pressure is being applied. I will say, though, that I don't hear anything like that when roll my '18 Low Rider around in the garage.
