2018+ Softail Models Breakout
Guys who are tuned and have the OEM CC installed
Old Aug 4, 2020 | 10:48 PM
OrangeThunder's Avatar
OrangeThunder
Default Guys who are tuned and have the OEM CC installed
If I have been researching correctly, the PV flashes the OEM ecu with engine tuning mods so the CC function is not messed with. What about the Tmax? I see that it is a replacement ecu stand alone system. Does the CC function still work with it as well? I'm slightly leaning towards the PV, but the Tmax looks very simple to install and operate. My future goals are the Comp Cams 246A cam, bigger TB and other supporting mods.
Old Aug 4, 2020 | 11:17 PM
Hulkss's Avatar
Hulkss
The Tmax is an Alpha-N EFI controller which uses throttle position (Alpha) and engine RPM (N) to control the engine fuel and ignition. The OEM ECU is a Speed-Density controller which uses engine RPM (Speed) and Air Density (intake manifold air density is calculated from Manifold Absolute Pressure and Temperature, MAPT). While both get the job done, Alpha-N is typically recommended when big cams with lots of overlap cause the MAPT sensor reading to be inaccurate. Speed-Density is generally considered to be the superior system for street use.
Old Aug 4, 2020 | 11:41 PM
OrangeThunder
Good to know, I'm just wondering if the CC works with a Tmax as well, since it's an ecu replacement.
jamala00
Audio Systems
Apr 2, 2020 04:33 PM
hdmunro17
Engine Mechanical Topics
Jun 28, 2017 11:17 AM
worked4it
Dyna Parts
Jan 30, 2016 03:56 PM
fburmer
Sep 23, 2008 09:10 PM
