How do I de install my Thundermax
Old Sep 23, 2008 | 08:39 AM
fburmer's Avatar
fburmer
Stage IV
Default How do I de install my Thundermax
I am getting ready to sell my 07 Road King Classic and I want to remove the Thundermax Auto Tune and Re Install the OEM ECM. Are there any special steps to reset the OEM ECM once it is installed? If so what is the procedure. Any help is appreciated.
Old Sep 23, 2008 | 09:03 AM
stro1965's Avatar
stro1965
No, once you hook up the OEM one it should just fire right up.
Old Sep 23, 2008 | 07:12 PM
fburmer's Avatar
fburmer
Stage IV
Thanks. I asked this question to the tech at my Harley shop and he tried to sell me an entire reprogram for $150. I'm not a mechanic but I'm not a dummy either. That just didn't make sense.
Old Sep 23, 2008 | 07:32 PM
deni's Avatar
deni
You need to replace the WB O2 sensors w/the OEM Narrow Band ones ?
Old Sep 23, 2008 | 07:34 PM
cHarley's Avatar
cHarley
If you installed pipes and a high flow A/C along with the ThunderMax (Stage 1), expect the bike to run like crap when you go back to the stock ECM.
Old Sep 23, 2008 | 09:02 PM
fburmer's Avatar
fburmer
Stage IV
I plan to put the OEM pipes and air cleaner back on at the same time. Won't everything work normally?
Old Sep 23, 2008 | 09:10 PM
John TN's Avatar
John TN
You will be fine with that setup basically back to stock, change the wego's as suggested.
jamala00
Audio Systems
Apr 2, 2020 04:33 PM
redsox
Mar 27, 2019 12:38 AM
redsox
Nov 1, 2018 12:44 PM
xl8832007
Aug 12, 2013 06:09 AM
HyperM3
Jun 2, 2013 06:13 AM
