2018+ Softail Models Breakout
131cu factory engine for some new Softails
Old Aug 26, 2020 | 05:41 PM
HDean's Avatar
HDean
Default 131cu factory engine for some new Softails
https://www.google.com/search?client...newer+Softails
https://www.harley-davidson.com/us/e...%7D/p/16200341
Old Aug 26, 2020 | 05:52 PM
Birtyyy's Avatar
Birtyyy
Fits '18-later SoftailŽ models (except FXFB and FXFBS). Requires separate purchase of Cam Drive Retention Kit P/N 25566-06. Installation may require Cam Spacer Kit P/N 25928-06. '18-'19 models require separate purchase of High-Capacity Oil Pump P/N 62400247. FXDR114 models require the separate purchase of 65600300. All models require ECM calibration with Screamin' Eagle Pro Street Tuner for proper installation.
Old Aug 26, 2020 | 06:00 PM
OldMike's Avatar
OldMike
Weird fits note.
Old Aug 26, 2020 | 06:12 PM
Hulkss's Avatar
Hulkss
Originally Posted by OldMike
Weird fits note.
Somebody copied the notes from an engine stage kit by mistake.
Old Aug 27, 2020 | 03:40 PM
AJ88V's Avatar
AJ88V
I was wondering if this motor would fit. Seems like it might be a better investment than a big bore kit, intake, cams, etc., plus labor, especially after selling your good used motor.
But I also wonder how the transmission would hold up to this much torque.
Old Aug 27, 2020 | 04:03 PM
Hulkss's Avatar
Hulkss
If you use the H-D motor and tune, I believe you will be OK. H-D will have some form of torque limiting built into the tune. Don't worry, there will still be plenty of torque to have fun and not break your drive train.
I would use the H-D Smart Tune Pro with the wide band O2 sensors. Works great on my stage 2 bike.
Old Aug 27, 2020 | 04:49 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Interesting subject, warranty or not is the question.
If not, this site caught my attention as others have.
I just havent seen any posts directing any info to this one.
https://suburbanharley.com/Parts-Catalog-M8-Pistons
Old Aug 27, 2020 | 09:01 PM
Hulkss's Avatar
Hulkss
Surburban Speed uses Mahle Pistons. They are very well made.
Old Aug 28, 2020 | 01:26 AM
LuvdemBobberz's Avatar
LuvdemBobberz
According to the HD.com website,
"Engine features one-year manufacturer’s warranty for unmatched confidence
• Eligible for coverage under factory vehicle warranty when dealer-installed within 60 days of vehicle purchase"
So, it appears to have a limited 1 year manufacturer warranty coverage on the motor but it can be rolled into factory warranty coverage but the dealer must install it in a new motorcycle (60 day cut off period from purchase) in this second case.
Old Aug 28, 2020 | 09:33 AM
AJ88V's Avatar
AJ88V
I also suspect you'd need to use one of the Harley tuners with a Harley tune to get the warranty. Add another grand, but might be worth it for the peace of mind.
