2018+ Softail Models Breakout
Sticky Throttle
Old Aug 27, 2020 | 08:35 AM
ss3964spd's Avatar
ss3964spd
Default Sticky Throttle
Do any of you find that the throttle is a little sticky? I think "stiction" is the correct word.
Only time it's noticeable is when making very fine throttle adjustments. I haven't taken the control apart yet to see how it's built to determine if it can be effectively lubed.
Insights appreciated....
Old Aug 27, 2020 | 10:38 AM
Hulkss's Avatar
Hulkss
No stiction at all here. There should be some axial end play if the controls are positioned correctly.
Old Aug 27, 2020 | 11:56 AM
ss3964spd's Avatar
ss3964spd
Thanks Hulk. There is some end play so it's not sticking due to a lack thereof. I'll take it apart sometime to have a look.
Old Aug 27, 2020 | 03:28 PM
AJ88V's Avatar
AJ88V
Yeah, there should be no stiction.
Stickiness could be either with your grip/tube on the bar or in the switch housing. My handgrip is borderline rattly - easily rotates slightly fore/aft, and even some small linear movement along the bar tube.
Old Aug 27, 2020 | 04:54 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I insist on minum play at the throttle.
Throtle by wire today, not our old HD's.
My first thought something else other than the housing?
Old Aug 27, 2020 | 05:44 PM
ss3964spd's Avatar
ss3964spd
It's not that there was any "play" at the throttle like there can be with a cable operated throttle. It's more about overcoming the initial resistance in the movement. The hand grip itself has plenty of jiggle to it, end play was probably about 1/8". So it's not that it's too "tight" anywhere.
As it turns out most of the stiction appears to be in the largely plastic electronic throttle assembly/mechanism at the end of the bar. Can't remove the assembly without disconnecting the wires, but some judiciously applied shots of silicone lube seems to have helped, and a very thin coat of high temp caliper grease on the bar itself for the grip to ride on as an extra measure. When re-assembling I snugged up the end play to about 1/16th". The stiction hasn't been eliminated but definitely reduced.
Old Aug 27, 2020 | 05:47 PM
Tampa Fatboy
I need to look at this throttle by wire setup before commenting, my bad. Let us know whats up. GL
harley0101
Dec 18, 2014 09:53 PM
ije
Apr 14, 2014 07:47 AM
Mast1017
Sep 13, 2011 01:41 PM
sstlcm08
Jan 23, 2011 12:20 PM
stephenabel
Dec 19, 2010 07:09 PM
